Results 1 to 10 of 17
Thread: Anyone changed their own Clutch & DMF?
    Engine : 1.9 CDTi
    Default Anyone changed their own Clutch & DMF?
    Just looking into changing my DMF and clutch.
    There is a tool listed but I cant ever remember having to use one.
    This is the tool:
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Is that the tool for re-setting the self adjusting clutch?, if so you only need it if you are re using the clutch. If your replacing the clutch and pressure plate with new no special tools are required
    Regular Member Jezzy's Avatar
    S.E
    Clutch alignment tool
    Engine : 1.9 CDTi
    Yeah its to reset the clutch.
    Always replaced clutch when doing DMF's so probably whey I have never used it before lol.
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    never changed a clutch/dmf yet, on my list of things to have a go at.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    i have and is not nice at all. And if its really bad you will need a grinder to cut the flywheel off.
    p.s if you got a f40 gearbox they look lite there not.
    Engine : 1.9 CDTi
    Yeah its an F40 but got workshop facilities and 2 poster ramp
    Sep 2010
    in a box
    you be fine then as sed if flywheel is bad it is not nice. take you about 4/5 hours thats how long i did it in with the fathers help worst bit bleeding it mine didnt want play fair and you have same car as me just see it in your name signums all the way
    p.s replace everything and dont forget 2.4liters of oil im sure its that some one will say if im wrong good luck m8
    Engine : 1.9 CDTi
    What happens to the flywheel to require them to need to be ground off?
    Mine rattles but its not that bad so if its going to get worse and make it harder I may have to do it sooner rather than later.
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    something about the bolts get really really tight/worn if the DMF is allowed to rattle for a long while
  1. Clutch and DMF changed, now awfull noise!
    By redmans in forum Engine & Drivetrain
    Last Post: 15th July 2012, 18:21
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. DMF, Clutch and bushes changed
    By lee gsi in forum Engine & Drivetrain
    Last Post: 26th July 2011, 11:16
  4. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  5. Changed clutch and flywheel yesterday
    By stupot555 in forum Engine & Drivetrain
    Last Post: 7th July 2011, 22:28
