Thread: Help needed i have Bad Wobble
    Sep 2009
    Default Help needed i have Bad Wobble
    Hi, i could do with some help/advice here guys.
    i have developed a really bad wobble it only happends upon accelaration from 30mph right the way up 70+ mph.
    the wheel balancing has been checked also took my flakes off and put my standard wheels back on but still it happens.
    Any ideas on what it can be ...... ?
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    track rod ends> you wacked it in the snow>?
    EVERYWHERE
    Lower front suspension arm/stub axle assembly may be damaged if kerbed. Is it a regular wobble, like wheel balance, or does it vary?
    Sep 2009
    Quote Originally Posted by hairy31 View Post
    ive had new track rods.
    also had a new RNS wheel bearing.
    Quote Originally Posted by diesel dog View Post
    it is a regular wobble mate. if im costing there is no wobble. the wobble is only when accelerating and im doing 30+mph
    The front drop links on my car are near the end of their life, that is causing a very slight vibration on the steering wheel above 40mph
    EVERYWHERE
    Quote Originally Posted by crazy-dee View Post
    Heard of this before on a car with a bent driveshaft!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Any noise from the front wheels between 30-70 when accelerating or full lock turning at low speeds?
    Had this on my GSi and turned out to be the front n/s wheel bearing/hub assembly. Due to the modern design of bearings, you won't detect any play in them simply by rocking the wheel in the old fashioned way.
    Sep 2009
    thinking on it, it might be because i was getting wierd sounds from the front o/s wheel in the snow every time i had wheel spin.
    Quote Originally Posted by gtr1000 View Post
    no mate, i was getting hoo-ling sound that turned out to be the rear N/S wheel bearing but no more noises since.
  1. Wheel Wobble - What next?
    By logi6260 in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2011, 16:13
  2. Wobble!
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2011, 12:20
  3. bum wobble
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2011, 12:47
  4. Wobble between 20 and 30 mph
    By Tigger in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2011, 00:28
  5. Wheel Wobble
    By rsocon in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 14:15
