Results 1 to 10 of 13
Thread: Reset of Remaining Oil Life
    May 2007
    Norway
    Default Reset of Remaining Oil Life
    I'm about to do an oil-change in my 1.9 DTH and I wonder how/if I need to reset the Remaining Oil Life value.?
    Or does Remaining Oil Life perhaps follow the ServiceInterval-reset?
    As far as I am aware it is not possible to reset the oil life within the service indicator
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as M8 says just the one reset
    May 2007
    Norway
    Thanks.
    I'm going to reset the ServiceInterval then.
    Your car is out of warranty so you can do what you like with the service indicator
    If you are adding additional oil and oil filter changes, then simply reset after each
    Just don't forget to carry out the other service points at least once every year / 20K miles
    May 2007
    Norway
    Yepp, I'm going to keep the regular/annual service at a garage, but decided to start changing the oil and filter one additional time each year as I do run the car for a short distance very often and this will deteriorate the oil-life.
    I get an Remaining Oil Life of approx 27% at this point. (Oil changed last May, approx 10k miles ago)
    I do not want a turbo-failure.
    I'll reset the ServiceIndicator and check if the RemainingOilLife is set to 100% again.
    Bristol
    Vehicle : CDTI 150
    Oil life remaining can be set by Tech 2 or Vaux Com.
    This is only if car on Eco Flex servicing.
    Annual is 15K/12mths, its a good idea to change more frequently if only doing short journeys. I do mine every 6mths regardless of mileage.
    May 2007
    Norway
    Changed the oil and filter today, and did a reset of the ServiceIndicator. However, did not have to do this as it did not clear the RemainingOilLife-value. Going to have it Tech2'd to reset the OilLife. Thanks for the tip lesj.
    Where and how does the car display the remaining oil life?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If the car is on Eco Flex servicing and you press the daily mileage reset button, the display in the rev counter will show the miles until your next service.
    Only on pre-facelifts though
  1. 'Range' or 'Remaining fuel guestimate'
    By Ollie in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 19:27
  2. remaining parts mainly irmscher
    By adfrodsham in forum Parts for sale
    Last Post: 21st June 2009, 20:37
  3. Replies: 0
    Last Post: 25th June 2005, 16:13
resetting oil life opel signum 2005
reset oil life vectra c
vectrs c remaining oil
remaining oil life vauxhall forum
vectra c oil life left
