Thread: AirCon Question
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default AirCon Question
    Yes, strange time of year for such questions!!
    Anyway, went to get it gassed at the start of the summer due to it not having worked for a while, plenty of gas (i.e. full) but the clutch on the compressor was not engaging so thought no more of it. Checked the fuse tonight (seems there's quite a few pertaining to the AC!) and was missing fuse 18 so replaced it and now I get a change in engine noise when putting the AC on but doesn't go below 12.8 celcius.
    Any way of checking if the compressor is doing its job visually? Or could it just be needing a good running seeing as its been 'off' for so long?
    pre-face 150 cdti if that means anything.
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    ...........now I get a change in engine noise..................
    Yes usually the revs increase slightly on tick over to cope with the extra AC load
    Tain - Easter Ross
    Revs change for a second then levels out again. However, hold the revs at 1k, AC on and they go up by about 250rpm but still not as cold as it should be.
    Not wanting another summer of wet seats.
    Regular Member GAZWAH's Avatar
    darlington uk
    you should be able to see the centre part of the pump turning if the clutch is engaged.......try also feeling the pipes running of the air dryer,these should be hot if the system is workin.....can take a good five minutes to kick in
  1. Another aircon question
    By 111 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th December 2011, 01:36
  2. another aircon question
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 01:38
  3. Question about aircon
    By Ralphwells1967 in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 16:23
  4. aircon question
    By monty2000 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2010, 13:49
  5. Sorry Another Aircon Question
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 11:14
