Results 1 to 10 of 14
Thread: sluggish
    Regular Member chrosty's Avatar
    Jul 2010
    lincolnshire
    Default sluggish
    hi for you guys who dont know ive got a vectra cdti 150.
    The problem is that these past few days its been really sluggish on pick up untill the turbo spools up.
    Has anyone got/had the same problem and know what it is or mite be and how to fix it? all help appreciated
    cheers ben
    Regular Member Dazzy2006's Avatar
    Notts
    Iirc its usually down to the egr valve or boost sensor needs cleaning if sluggish under 2000rpm
    Jul 2010
    lincolnshire
    how do i clean them?
    Wales, UK
    There is a how2 on cleaing them mate, the EGR needs to be taken apart and cleaned once removed from the vehicle. Not sure about cleaning the boost sensor but its only little and should'nt be a problem ! These two go hand in hand when it comes down to being sluggish, before the turbo kicks in.....
    Let us know ho you get on
    Jul 2010
    lincolnshire
    will do mate cheers for the help.
    Notts
    http://www.vectra-c.com/forum/showthread.php?t=88845
    I could have sworn there was a guide in the how to section - this guide is for the dti but should be same principles
    http://www.vectra-c.com/forum/showthread.php?t=60856
    preston
    boost sensor cleaned with carb cleaner and soft toothbrush
    the egr can be cleaned this way too, the valve bit anyway.
    split egr into valve and solenoid, follow how to and drill solenoid bit, then clean and lubricate before reassembly.
    make sure you also remove soot from egr to maniold entrance
    clean both egr gaskets or better replace with new.
    repeat process every 3 to 4 months as routine maintenance
    also change to branded fuel and do airbox mod. it just will
    run so much better
    Jul 2010
    lincolnshire
    cheers im not the best when it comes to engines especially diesels but ill do my best cheers for the help.
    oh and the airbox mod is done already
    preston
    egr is 4 bolts to manifold, best with deep sockets and wrench
    egr to flexi pipe is 2 bolts again deep socket works well
    make sure you don't drop the gaskets
    split egr with torx bits
    then drill egr solenoid as per how2 with 3mm bit
    then give it a hefty thump with a punch to separate
    solenoid from body
    it seems complex but its really straightforwards once you've done it
    Jul 2010
    lincolnshire
    ok cheers mate will give it ago this weekend (providing its not snowing or im too hungover .)
  1. 07 SRi Sluggish
    By obews in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 20:30
  2. sluggish
    By iokarus in forum Engine & Drivetrain
    Last Post: 29th February 2012, 20:35
  3. Sluggish again
    By durham4416 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:20
  4. sluggish 1.9 cdt
    By thommo in forum Introduce yourself.
    Last Post: 16th March 2010, 14:57
  5. Car feels a bit sluggish
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 23rd March 2009, 09:28
