Results 1 to 10 of 14
Thread: Leather interion conversion opinions plz
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Default Leather interion conversion opinions plz
    Hi guys I have a quite good opportunity to buy half-leather seats and sides from '08 hatchback with small mileage. That's exacly what I wanted to do for a long time.
    As I know some of U have made a similar conversion. So the question is: is it a problematic swap, what about airbags (here included), and will english version fit to european???
    Thanks in advance!
    http://moto.allegro.pl/tapicerka-sko...384598621.html
    Regular Member badback's Avatar
    Runcorn
    Hi Mate, I swapped my interior for full leather and had no problems. It's quite easy to do actually, even for me with a bad back. I disconnected the battery for half an hour before starting, then just unplugged the connectors under the front seats. I can't see there being a problem with English to european lefthand/righthand drive etc.
    Regular Member Iezzi-martin's Avatar
    Jul 2010
    Birmingham
    I changed mine to full leather heated electric etc just had to put a fuse an run some wire to it easy only thing I think will be a problem is if it's a left hand drive an the seats are electric etc the driver seat has more on it than passenger seat
    Oct 2010
    Poland
    Cheers guys!
    Now I think there is nothing to be worry about, as I know seats are manually regulated and not heated. I was just worrying about airbags but I always have mine in case ;-)
    Thanks a lot :-)
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    is this a right hand drive interior going into a left hand drive car ???
    Oct 2010
    Poland
    Quote Originally Posted by ditchp View Post
    yep, exacly.
    Trim : Get a
    in that case then surely the seatbelt and the seat adjustment controls are on the wrong side of the seat's then no ??
    Oct 2010
    Poland
    Is it possible that in better versions seat adj controls are on both sides? If not, You're right - it's senseless.
    Trim : Get a
    i think that they are factory set for each specific vehicle market country....unless you are prepared to strip down each seat to see if the mounting point's for seat belt's can be moved from side to side then i think you are going to have problem's as even if you can swap seats over ie driver's seat from RHD car into passenger side of LHD car for controls there could still be a problem, and then saying that there are also the side airbag's to consider...
    edit:-
    looking at the picture of the interior it looks as though the passenger one has got the nessesary controls for adjustment so could be a straight swap over for you
    Oct 2010
    Poland
    I even cannot check it because it's goona be a shipment. But at least I know what questions exacly I should ask to the seller. Probably this is the reason why the price is quite low.
    Thanks for help, it's good to have a place to ask
  1. Leather interior conversion..
    By nikroc in forum Bodywork & Interior
    Last Post: 9th November 2012, 18:45
  2. What fuse for interion light?
    By amd in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2011, 00:00
  3. signum half leather - design trim and vectra full leather
    By TIMMAH in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 11th May 2008, 22:56
  4. Advice Required SRi seats leather conversion
    By cameraman in forum Styling
    Last Post: 16th September 2007, 23:20
