Thread: Headlight bulb replacement?
    Oct 2010
    Lincoln
    Default Headlight bulb replacement?
    How difficult is it to replace the dip beam driver's bulb on a facelift Vectra C (56 plate)?
    Been told horror stories about the entire unit having to come out to get at it?
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    To get at the headlights on a facelift there are two options. Take the bumper off (can leave the rivets in on the splash guard, resting the bumper on something so as not to scratch it) or you can remove the airbox (all of it) and the screen wash extension pipe thingy. Done
    To remove the front bumper there are two screws in each wheel arch, about 4-6 underneath the splitter and then the four on top (between headlights).
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 310 k !
    Depends how small your hands are
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I did this a few weeks ago, I removed the airbox to do it, I didn't fancy dropping the bumper.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Piece of cake mate, just fitted HID's to mine on a facelift.
    Left side: Twist out the washer fill pipe from its clip on the cross member and gently twist and pull out, then you can get your hands in and untwist the cover plates.
    Right side: Remove the airbox, just undo all of the air pipes, and sensor and then the whole box can be pulled out. First from the bottom mount and the bottom pipe, then work out the top two mounts. 10 minute job, and again you can access all
    (oh and don't forget the wiring harness thats ziptied on as I snapped my mount for it lol :P
    Really not as difficult as others have made out in the past
    13 Post(s)
    Quote Originally Posted by luke4487 View Post
    Nor is removing the bumper, which is the prefered route I would take.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I found it easier to take the washer fill pipe clip off the slam panel, twist the pipe free for passenger side, and, as above, remover airbox for drivers side. Plenty of room then. Too cold to lay on floor.
    Bordon, Hampshire
    The main negative to dropping/removing the bumper is that your going to scratch the paintwork on the floor... thats the only reason I wouldn't want to use that technique..
    Also from past experience putting a bumper on single handed can be a pain in the backside
    13 Post(s)
    Sorry, but unless you're a complete bufoon and stupid enough to lay the bumper face down, then you won't scratch the paintwork. Just take it off and keep it the same orientation as when it was on the car. If still worried, then lay down an old dustsheet or blanket first. Not rocket science.
    It's light as a feather. Hook one side on the wing, then the other side. Simples.
    If only changing one bulb you don't even need to remove the whole bumper anyway. Just undo one side far enough to undo and remove the headlight.
    Aug 2010
    Wolverhampton
    Default bulb replacement
    I have just come in to the warm again after changing the front offside dipped bulb. It took me 30 minutes from going out to coming back in. I used the removal of the air box method as the snow is still a bit too deep for kneeling on to remove the bumper. I did as someone suggested and did it with the engine warm to help soften the pipes but i still needed to use WD to fit the small rubber pipe. Next time it needs changing I can cut the time needed in half as I will know what tools to take out with me.
  1. headlight bulb replacement FACELIFT
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2012, 18:42
  2. Headlight Bulb Replacement
    By safrav in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 15:07
  3. Headlight Bulb Replacement
    By Hallzer in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2008, 16:12
  4. Headlight bulb replacement
    By mzctc7 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2008, 09:50
  5. Headlight bulb replacement
    By Davexctra in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 17:06
