Results 1 to 10 of 14
Thread: Which do you think is gonna work out cheaper
    Regular Member gibbon7000's Avatar
    lincs
    Default Which do you think is gonna work out cheaper
    Ok with gas getting more and more expensive, i'm wondering if anyone can help me out.
    I have a 3 bed semi, a fairly decent size one, not too small, not massive either. There's only me and my girlfriend living in it. Because we only need to heat the lounge and bedroom (kitchen heats itself from the cooking side of things) i'm wondering if its cheaper to use the cental heating as little as possible, basically just enought to stop the pipes from freezing and using my open gas fire in the lounge which would be on most of the time when were at home or would i better better off just wacking the CH up and forget about the gas fire?
    This is from a financial view only. Trying to save a few pennies thats all. I'm a right tight git
    Glasgow
    I would just use the central heating and keep it at a lower but comfortable temprature.
    Regular Member PORKBALLS29's Avatar
    Epping
    Tbh mate, the cost of gas for the fires at the moment is silly too. I sell it at work and our supplier has put prices up by nearly 50p per kilo in the last 3 months. So a 13kg butane is now nearly £24 and that may last you 4 days at a push! So i.d say just use you central heating on low.
    lincs
    Quote Originally Posted by PORKBALLS29 View Post
    Just to add, my gas for the fire is mains gas
    Epping
    lol. Ok mate, thought you were talking about a little cabinet heater.
    Regular Member david.aka.judas's Avatar
    Suffolk
    we've just bought a 1.1kw oil filled rad to warm up the room were in, it saves turning the heating on for rooms were not in.
    we only use it in addition though.
    lincs
    No worries, probably the way i explained it
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Quote Originally Posted by gibbon7000 View Post
    We have a wood burning stove in our 2 up 2 down country cottage we keep this alight 24/7 when its really cold, we have bottle gas central heating I changed the boiler to one of the latest combi boilers and it cut our has consumption by nearly 50%, they are really efficient
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    Try an extra pullover and turn the heating back, and ............... keep the doors between the rooms closed.
    Norwich
    Trim : SXi
    Engine : 2.2
    Problem is this, You heat the lounge,bedroom and bathroom. Turn the rads off in the other rooms. You will find mould and damp starts forming on the walls which in the long run will destroy any materials in the room and once the damp is in the walls it will be a pain in the butt to get rid off. Also if you only heat the rooms you are in everytime you open the doors to another room the heat is sucked into that room and the cold comes through.
    Thermal curtains provide very good insulation and keep the heat in. I know this sounds stange but make sure you have a trickle vent open in every room it will help remove condensate and allow a fresh steady flow of air that is easier to heat.
    Also if you do have a lot of condensate in your rooms (You know when the missus hangs washing over the rads!) it takes more time and heat to heat the moisture in the air in the room. I run a condensor once a week in the winter for a night and can normally pull around 2 litres of water in 12 hours.
    I used to suffer from a really cold house I had the boiler done and I redid the central heating but it still was not 100% but doing little things like the above really helps and have cut our bills down a lot.
  1. Is this a good buy or could i get it cheaper
    By mattbrad30 in forum General Chat
    Last Post: 9th September 2012, 00:53
  2. Which would be cheaper
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2011, 17:57
  3. what would be cheaper?
    By delboy2028 in forum Bodywork & Interior
    Last Post: 19th January 2010, 00:56
  4. Cheaper Petrol
    By KC in forum General Chat
    Last Post: 28th October 2008, 19:17
  5. Cheaper Fuel
    By kitchpoo in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2005, 00:51
