Thread: Spot the difference
    Newbury
    Default Spot the difference
    I ordered a thermostat from ebay supplier Revsonline. The part fits the Vectra C 1.8 so I ordered it, went to fit it only to find out it is different to the one I was replacing (no way of it fitting). so I had to put the old one back in. Anyone aware of a different style of thermostat (see pic, old one on the left with the new gold one on the right).
    Ordered from http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300481906090 (in case anyone else needs to order one, postage was very quick.)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are the dimensions not the same? I would have fitted it if they were
    Jul 2009
    The Rift, Cardiff
    You need to pull the pin out of the housing thats left from the old stat then the pin on top of the new stat goes in. I thought they were different too, but just used a pair of pliers to gently twist the pin out.
    Sodding Typical on Sea
    It's not unusual for them to look different from alternative makers as long as it fits the housing it will be fine in service.
    Newbury
    AHA I see! I did give the pin a little tug but thought it was part of the housing. Excellent, i'll wait for the snow to clear and have another go. Cheers guys.
    P.S. I'll be using some instant gasket goo stuff instead of the rubber ring it comes with as that was hard work trying to put that back with that on!
    MERRY CHRISTMAS LADS!
    Newbury
    Yep same dimensions (according to visually looking at them), cheers.
    Be careful as the rubber ring does give a very strong seal much better than instant gasket IMHO
    Newbury
    oh ok. Use both?
    Jul 2009
    The Rift, Cardiff
    I used the old gasket, gave it a clean, then put instant gasket in the channel on the housing, then put the old flat rubber gasket in then more instant gasket on top.
    Here's a pic of my old stat, the new one was from the same seller you've linked, so definately is the correct one.
    Newbury
    Gotcha. Otherwise how the **** do you manage to keep the round band in the channel/shape of the housing without it pinging back into a round band again. I've already binned the old gasket, I try not to re-use gaskets on anything if possible (lesson learnt there then).
  1. spot the difference
    By recoveryman in forum Comedy & Humour
    Last Post: 20th June 2011, 22:26
  2. Spot the difference
    By omega63 in forum Handling & Braking
    Last Post: 4th September 2010, 17:17
  3. Spot the difference....
    By spoons in forum Non Vectra C/Signum Album
    Last Post: 24th December 2009, 14:28
  4. How to spot the difference
    By NeilB in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2007, 10:53
  5. Spot the difference
    By MalcGSI in forum Quick Photo Album
    Last Post: 2nd August 2006, 15:12
