Thread: 1.8VVT Don't neglect spark plug change!
    Dec 2010
    North Hampshire
    Exclamation 1.8VVT Don't neglect spark plug change!
    Hi,
    New to Vectra, new to Forum: hope I might save somebody some trouble and expense...
    My car is a '57 plate with 63K (warranted) bought at auction last week, with service stamps at 24K and 45K, so I was planning a service very soon.
    Third day I was driving it, started to misfire and the ECU warning light came on. A friendly neighbour hooked up the TECH2, which showed 'misfire on cylinder 1'.
    I'm sure the plugs were the ORIGINAL ones! Virtually no centre electrode left and hence a gap of about 2.0mm instead of 0.8. Sadly, replacing the plugs did not solve it - I had to replace the COIL PACK too!!
    This makes sense because the excessive gap would put a greater 'strain' (ie more than double the voltage) on the coils which seems to have caused the internal insulation on one or more to break down.
    So - if only I'd changed the plugs a day earlier, I could have saved £90.
    All part of life's rich pageant
    Peter
    Oct 2009
    cheshire
    Peter yeh blob on with that, ive got a 1.8vvt sri on an 06 done 47k with I think original bosch plugs from new, no centre electode left AA found misfire on 2 cylinders, put new plugs in but NGK's ZFR5F, still didnt run right, I thought it was these plugs at first but its the coil pack like you said, the AA mech said if it still runs crap after new plugs try a coil pack, bought the original Delphi £90.
    ALLS I WOULD SAY IS CHANGE YEH PLUGS EVERY 20K
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    i change mine once a year when i give mine the full monty its daft not to..still had to put a coil pack on about 2 months ago 64 quid all in from autovaux trade price
    Sep 2009
    Audley STAFFS
    I put a set of VX plugs in my none vvt, 10,000 mile(12 months) later thought I would have a lookie see if they were ok as mpg had droped a bit, I was very surprised to see that although the plugs looked in perfect condition/ colour ect, the gaps were all over the place/all three on each plug were different some massive some nearly closed up,, put a set of bosch super in then checked them after 10,000 miles,,,perfect.. perhaps the VX plugs were a faulty batch,
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    yep I have had same issue exactly, slight misfire which turned into severe misfire...changed plugs mostly fixed it but needed new coil pack to get rid completely. Z18xe
    Oct 2009
    cheshire
    Smile
    Got my new Genuine Delphi Coil Pack today, 2 mins to fit, runs sweet as a nut again,
  1. 1.8VVT stripped spark plug thread
    By Cleared To Land in forum Engine & Drivetrain
    Last Post: 14th December 2012, 15:15
  2. Spark plug change help
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2011, 15:12
  3. Plug change 1.8vvt sri
    By big oak in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2011, 20:04
  4. Spark Plug change
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 10:54
  5. 3.2 Spark Plug Change Help
    Last Post: 11th May 2007, 14:29
spark plugs vectra c 1.8
vectra c 1.8 spark plugs
vectra 1.8 vvt spark plugs
show what tool to change spark plugs vectra c 1.8 ls
vauxhall insignia spark plug change
how to change spark plugs on a Vauxhall vector 1.8 2007 model
vectra c 1.8 vvt spark plugs
vectra 2008 spark plugs
how many spark plugs in a vauxhall vectra
vectra c spark plugs
How to change spark plugs on vauxhall insignia
vectra c 1.8 spark plug change
when should i change my insignia spark plugs
tools to change zafira coil pack
genuine vauxhall vectra spark plugs
what spark plugs for 1.8vvt vectra
zafira b 1.8 change spark plugs
vauxhall insignia 1.8 sri spark plugs
How to change spark plugs on Vauxhall Vectra 1.8vvt
spark plug vectra 1.8
2008 vauxhall vectra 1.8 sri what spark plugs
vauxhall vectra 1.8 sri 06 plate spark plug
what are the 1 to 6 pin connections on vectra c vvt spark coils
opel vectra c spark.plug condition
vectra c can old worn spark plugs cause engine to run sluggish
