Thread: 2ltr dti misfire
    Nov 2010
    Vectra land
    Default 2ltr dti misfire
    Hi,
    i've got a 2.0 dti vectra that misfires when its started, but only does it when car has been stood for a while (6 ish hours) doesn't matter if glow plugs on or not. There is a white cloud of smoke when this happens, unburnt diesel?
    i have had starting issues, that don't seem too bad now (touch wood) replaced glow plugs and module, bleed back pipes and t peices, injector seals, fuel filt and seals, coolant temp sensor, battery, cleaned egr etc. but still got this misfire.
    only happens when car has been stood and doesn't go away when reved. have ran injector cleaner through system and ran a full tank of ultimate diesel through but still no better. Got no codes when done diagnostic check.
    Was thinking bout replacing fuel filter housing, but thought i'd check u guys for ideas first.
    Thanks in advance for your help
    Jono
    East Midlands
    I'd be looking at changing the crank sensor mate for what they cost.
    Nov 2010
    Vectra land
    Wasn't sure if it was a little air in the system as only does it when been stood a while/ engine cold
    wouldn't crank sensor throw a code and do it every time the cars started, could it cause a misfire?
    Nov 2010
    Vectra land
    forgot to mention, misfire starts when cars been running for a few seconds and not straight away, and clears itself after a minute or so. cheers
    north east
    crankshaft sesnor if its mis fireing, wont give you a code till it completely fails but will occasionly give you random codes like air mas incorrect or Cam shaft sensor (this is always funny as it doesnt have a cam sensor)
    Nov 2010
    Vectra land
    I have fitted a crank sensor today so will see how it is in the morning although did misfire when started after work. I have noticed performance is tempromental too. Any ideas would be greatly welcomed, apart from fuel filter housing, not too sure where to go next?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by jono m View Post
    White smoke could be coolant. Does it use any coolant?
    The fact it only does it after the car has stood a bit - coolant could be seeping into one of the cylinders via the head gasket. Possible, but unlikely. It only takes a drop of coolant to produce a nice cloud.
    Nov 2010
    Vectra land
    doesn't use any coolant mate, think the cloud is unburnt diesel.
    north east
    try disconnecting the coolant temp sensor and starting it as this is part of the glow plug circut if the sensor is faulty it may be over fueling once started
    Nov 2010
    Vectra land
    have tried that mate, tested circuit too and all fine. replaced coolant temp sensor also.
  1. saab 93ss 2ltr t & 2ltr T wots the difference???
    By markspark in forum Engine & Drivetrain
    Last Post: 27th June 2010, 14:47
  2. confused by 2ltr
    By darveccy_c in forum Introduce yourself.
    Last Post: 14th January 2010, 22:05
  3. what oil for a 2ltr turbo
    By STAV in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2007, 16:33
  4. more problems with 2ltr dti
    By deano1 in forum Engine & Drivetrain
    Last Post: 14th February 2007, 13:34
vauxhall vectra dti missfire when cold
vectra dti misfire when cold
