Results 1 to 10 of 17
Thread: Spanner light
    Sep 2009
    Glasgow
    Default Spanner light
    Started car this morning after getting my tattoo touched up, tried the wipers and still no water, drove off and noticed spanner light on dash so took the car for a spirited run and it drove better than ever, got home switched of and then started again and no light my car is due to get booked in for stuck open thermostat ast temp never goes above the first marker and mostly sits at zero in cold weather, could this be the cause of the light being on, but surely it would have stayed on.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    No - spanner light wont come on with a stat issue.
    Was the car cold when you started it and then got the spanner light.. I take it you have a CDTI.
    Suggest its a glow plug fault if it was cold, and then went on restart when the car is warm. Pretty common TBH.
    You will have a stored code in the ECU that will tell you.
    Sep 2009
    Glasgow
    car was driven for about 10 miles, but didnt heat up because of thermostat, sat for an hour and then restarted, thats when light came on, there has been days it's been -17 and had no light on startup, yep it's a cdti, will keep an eye on it.
    Sep 2009
    Glasgow
    what lights should stay on when ignition turned to power, my spanner and engine managment light stay on till i start the car, im sure this is normal, getting a bit paranoid
    Middlesex
    Trim : SRI
    Mileage : 100k
    Emmisions will stay until engine is running.
    The Spanner will come on with the ignition IF you have a stored fault code (which you do). Normally you will not see the spanner at all.
    If it goes out when running (the spanner) it means the fault is no longer present.
    HTH
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Sep 2009
    Glasgow
    will the fault clear if not present after x amount of restarts
    Glasgow
    If the car and spanner comes on with the ignition and then goes off after a couple of seconds as per what the owners manual says its nothing to worry about. Yes it will clear after a while if it does'nt re-occur.
    If the car and spanner comes on whilst driving or comes on and stays on then time to get it looked at.
    Nov 2010
    St.Ives
    Sorry to hijack but is the thermostat thing a common problem as i noticed mine hardly moved during the really cold weather and now it goes to just below the first notch.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by nokiaman1978 View Post
    If that same eror doesnt come back then yes.
    TBH Id want it read first so I know where there may be a weak area..
    A
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
