Thread: shaking whole car
    york
    Angry shaking whole car
    just recently my car is running awfull a slight touch of accellerator it hesitates nearly stalls then picks up it shakes the whole car on tickover and sounds very loud , though may be flywheel had new one fitted bout 3 months ago but noise doesnt change when clutch depressed it almost feels like engine is unballanced. Really sick of this car now.
    Regular Member Exclusive BV's Avatar
    West Midlands
    what engine is it m8?
    did you get anything else changed when the flywheel was done?
    york
    just cluth and dmf its cdti 120 .06
    West Midlands
    Sounds to me like your engine is short of something so my guess is air or fuel starvation.
    When did you last change the fuel filter?
    It could also be the MAF sensor playing up
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Going by your first post either:
    - EGR is jammed open
    - 3rd injector wiring loom is needing replaced (not 100% if it affects the 120 though)
    - One or more injectors are out of tolerance for some reason.
    Gazza4
    york
    well justhad injectors fuel tested 1,2 seem fine filled jar same time 3rd didnt even reach jar and 4th filled jar quicker than 1 and 2. the 3rd injector looks like wiring has been done also turbo covered in oil took pipe off boosying fine no play reckon oil seal has gone in turbo. how much would new injector be
  1. Car / engine shaking
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2016, 19:14
  2. Engine Shaking the whole car
    By inchy1981 in forum Engine & Drivetrain
    Last Post: 17th December 2012, 14:34
  3. Odd shaking - Am I going mad
    By Tim525 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 17:31
  4. Shaking 3.2?
    By jamesr in forum Engine & Drivetrain
    Last Post: 28th September 2008, 08:03
  5. shaking at idle
    By POAH in forum Engine & Drivetrain
    Last Post: 19th December 2006, 08:10
cdti whole car vibrates on tickover
