Thread: New member / sri edition 100 owner !
    Dec 2010
    wirral
    Default New member / sri edition 100 owner !
    Just wanted to say hi to all and a big thanks already as i have joined after gaining tips for my boost loss / limp mode problems (grrrrrr).
    I have replaced both my solenoids but still got spanner light galore, so now need to do a hard reset and check my oil level, it seems from reading the forums on here that my problems will then be over !
    Cant wait !
    Phil
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Welcome mate, the spanner lights should clear themselves if the problem has been fixed after a few good starts.
    To "hard reset" disconnect the battery for 15 mins.
    As for checking the oil, run the car up to temperature, switch it off and let it sit for 5 mins. Then check the oil
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Welcome from a former Edition100 owner. Once your problems are over, you will really enjoy your motor.
    Regular Member leonvectrac's Avatar
    south shields
    welcome along
    WGAF#5
    hi Phil,
    welcome along to the Forum
    how many miles has the car done ??
    if you still experience issues following replacement of the solenoids i can give you a few more pointers in relation to other bits to check= before removing and replacing the diaphram in the intergrated recirculating dump valve as the repair kit alone is in the region of £100
    regards
    Dez
    Dec 2010
    wirral
    Hi all, thanks for the welcome and tips, my vec has done 109k - probably the highest I've seen on a 100 !
    I was still getting problems up until an hour ago when I replaced the air filter, going well now and fingers crossed that was the culprit, maybe a mixture of a few things, well it's now had a recon turbo and a full service and hard reset.
    I was a bit dubious about the turbo after I got it back from the cowboys that rebuilt it but as I say finally (hopefully) looking good
    Regular Member ant6566's Avatar
    gwent
    ive got one of these,and the forum is an absolute mine of info.done solenoids as well about 1000 miles ago,and flying along,albeit at 26-30 mpg on a good day.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Hi Phil welcome to the mad house
    Irmscher Insignia CDTI 130
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Welcome m8.
    Gazza4
    Dec 2010
    wirral
    Default cheers !
    So many welcomes ! Well i changed air filter but car is still intermittently cutting boost / feeling like its choking a bit ??? and so having no go in it, sometimes with no spanner light too ?? then after restart is ok and pulls like a train - for a bit.... !
    Its really puzzling me now, might just drop it off at dyno demon or similar specialist ?
    Unless anyone knows what else to check ? got a load of new vacuum pipe to replace originals tomorrow for a bit of elimination and the geniouses at turbo-solutions gave my turbo back with a very slight twist on compressor side housing when reassembling the housing so gonna reset that hoping to get actuator right. fuel filter next too maybe.
    Nightmare !, agin thanks for the help, great site.
    Phil
  1. New member, edition 100 SRI
    By Edit100T in forum Introduce yourself.
    Last Post: 6th July 2012, 14:31
  2. Hello all.....Edition 100 owner here
    By Steve 100 in forum Introduce yourself.
    Last Post: 3rd April 2012, 21:31
  3. Vectra Edition 100 owner? Total Vauxhall needs you!
    By Turbodave in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2010, 10:21
  4. New Owner and Member
    By Marko-B in forum Introduce yourself.
    Last Post: 15th January 2010, 14:15
  5. Hi new member & owner
    By Pingu71 in forum Introduce yourself.
    Last Post: 8th April 2007, 16:06
