Thread: removing throttle on cdti will it need reprgramming tech 2 when put back on
    midlands
    Default removing throttle on cdti will it need reprgramming tech 2 when put back on
    im cleaning the egr,boost sensor and thinking of doing the throttle body on my vectra cdti 150
    if i remove the throttle to clean will the electrics need resprogramming eg tech 2 or is it just a matter of bolting it back on
    Oct 2009
    Luton
    No reprogamming required
    midlands
    cheers, is it easy to remove and i have read the electrics gets full of oil and should be cleaned if so what with and isnt there a risk of damaging the electric
    Oct 2009
    Luton
    It's easy, esp. with egr etc removed. Carb cleaner & rag should do job. The function of the TVB on the cdti's is to stop engine over run when switching off so I wouldn't touch the electrics unless you have an issue with this or starting issues.
  1. No throttle response Cdti 120
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 1st August 2012, 13:05
  2. door mirrors - removing the back covers?
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 21st February 2011, 23:30
  3. 1.9 CDTi 150 Throttle Body Location
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 08:12
  4. help needed on removing back door glass please guys!!
    By maddogwhite27 in forum Bodywork & Interior
    Last Post: 30th November 2008, 22:43
  5. V6 CDTI (EGR & Throttle Valves)
    By dbarua in forum Diesel Engine related
    Last Post: 12th December 2007, 20:10
