Thread: Diesel fume smell at start up
    Engine : 1.9 CDTi
    Default Diesel fume smell at start up
    When I start the car quite often I get a diesel fume smell at start up (Can smell it through the heater vents).
    Only thing I could find was one of the breather hoses that goes into the black canister under the inlet manifold isn't as tight as I thought it should be (It just pushes into the canister).
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Check that the exhaust flexi isn't knackered
    Engine : 1.9 CDTi
    It doesnt do it all the time.
    Just at start up.
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Are we talking about fumes like from a can of diesel or exhaust gasses? If it's fumes, you must have a diesel leak obviously. Exhaust gasses could be comming from a break in the exhaust system, a knackered gasket, one of the manifold nuts/dowels working loose, a cracked manifold...
    woking
    I get this at start up but only on cold days
    EVERYWHERE
    Leaking EGR system is favourite (if it's an exhaust gas smell). They tend to get taken to bits quite frequently and diesels use EGR at start-up, unlike petrol engines.
    Regular Member Craig1985's Avatar
    harwich essex
    Mine is the egr as it only done it since cleaning it. I reused old gasket
    Regular Member sloper's Avatar
    Oct 2010
    bradford
    Ive got the same problem, and the fumes smell continues through the vents when im using the heater, im suspecting a leak on the swirl valves on the inlet manifold
    preston
    sometimes on a frosty day, i've obviously got blowers on full to defrost,
    if the wind is blowing fumes back towards front of car, they'll be sucked back in through the venting system...
    i'd also check EGR gaskets and make sure that bolts are tightened fully, although if there is a leak in the egr system, i'd expect some reduction in performance as well
    Oct 2010
    bradford
    Spent 4.5hours in the car going nowhere other day cos of the snow chaos, nearly was gased, had to use recirc' on the vents.
    Had a nosey under the bonnet yesterday while engine running,cant smell fumes above EGR, but can above inlet manifold, put some washing up liquid over the far left valve and it was bubbling.
  1. Fume smell, smoke test??
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 6th February 2013, 19:07
  2. diesel smell
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd November 2011, 22:45
  3. fume smell, hard bitumin around injector???
    By dth150 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 20:58
  4. help with fume smell in grande punto.....
    By bobby-tupper in forum The 'Off Topic' room
    Last Post: 22nd February 2010, 17:48
  5. Diesel smell
    By ed taylor in forum The 'Off Topic' room
    Last Post: 26th January 2009, 21:14
https:www.vectra-c.comforumshowthread.php123926-Diesel-fume-smell-at-start-up
https:www.vectra-c.comforumshowthread.php123926-Diesel-fume-smell-at-start-up#::text=Leaking EGR system is favourite -up unlike petrol engines.
what is promlen qhen you smell diesel when start car
insignia smells of fumes when started
diesel car smells when started
smell of diesel when starting car
https:www.vectra-c.comforumshowthread.php123926-Diesel-fume-smell-at-start-up#::text=Are we talking about fumes a cracked manifold...
vauxhall diesel smellmy car smells of diesel on start upvectra c smell of fuel on starting colddiesel car smells when started from the engine https:www.vectra-c.comforumshowthread.php123926-Diesel-fume-smell-at-start-up#::text=Exhaust gasses could be comming a cracked manifold...zafira smelly exhaust cdtivectra 1.9cdti 07 smoking diseil fumes2010 cdti fumes in carvectra c smell diesel in cardo diesel engines smell on start upsmell of fumes in a 2007 vectra08 vectra 1.9 cdti diesel fumes in car vauxhall vectra 2006 1.9 cdti fumes on start upvauxhall vectra diesel fumes in cardiesel fumes on start upsmelly deisal fumes when first startdiesel smelling when starting the carsmell fumes sedici disel
