Thread: Starting problems cdti 150
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Default Starting problems cdti 150
    Hello! A friends astra cdti 150 has trouble with starting sometimes. It just wont start, and no fault code in engine. Hi has also checked immobilizer and its seems ok. I mechanic said it could be the ecu because the same problem was on earlier opels.
    Someone had this problem or has an idea what could be wrong? Sometimes it just wont start, and if he waits some ours and it starts with no problem.
    Aug 2010
    North of Norway
    Someone please?
    Oct 2010
    hull
    do a swap ecu with yours if its the same engine? would rule that out.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    You can't swap ecu without programmng it to your car as the immobiliser will cut out
    Aug 2010
    North of Norway
    Quote Originally Posted by chris167 View Post
    I have cdti 120, so its not the same software. And like Winnie write, the immobilizer must be coded to the car.
    Can op-com code the immobilizer by the way?
    kings lynn, norfolk
    I'm pretty sure it can but mot 100%
  1. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  2. starting problems
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 17th September 2012, 10:03
  3. Starting problems
    By Venom1924 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 23:55
  4. cdti 150 2008 auto 38k starting problems
    By StarDust2k5 in forum Engine & Drivetrain
    Last Post: 4th January 2012, 16:56
  5. V6 cdti starting Problems - new boy needs help
    By paul g in forum Engine & Drivetrain
    Last Post: 18th August 2008, 20:27
