Thread: Key Fob Mystery
    East Midlands
    Default Key Fob Mystery
    Just changed the battery in my 3 button key fob,as it was getting to the stage where you needed to be about 3 feet away from the car for it to work,simple job you may ask ,but not for me it is'nt.
    After changing the battery you need to sync the key fob to the car by locking then unlocking right,which is what i did,only now it does'nt work anymore.
    ?Anybody know what i have or haven't done right.
    ?Can the battery be tested using my multimeter.it's bin in my draw for 2 years,just a thought.
    Huddersfield
    Have you put the battery in the right way. Sounds silly but I did it once on a past car.
    East Midlands
    Quote Originally Posted by Paulrushton View Post
    Yep sure i have,the plus sign is facing upwards,correct i believe.
    Jul 2009
    The Rift, Cardiff
    Try it with the old batt back in. Will confirm or rule out possible damage to the fob.
    East Midlands
    Ok got to the bottom of it, unlocked the car door with the key opened it,the alarm went off
    so put key in ignition to see if it would start,and it did,but better still the remote now works so alls well that ends well,just to add theres no mention of having to insert key into ignition before it will work after a battery change...ah well sorted.
    Glasgow
    Hey, yeah to re-sync the key put it in the ignition and press the fob either the lock or unlock button cant be sure. I believe its in the owners manual aswell
    13 Post(s)
    Quote Originally Posted by macdad View Post
    Having just RTFM, there is mention:-
    After replacing batteries, synchronise remote control: unlock door using key in lock. Insert key into ignition.
    Quote Originally Posted by byebyeitsagsi View Post
    That was for Vectra-B models, and the Astra-G/Zafira-A.
    East Midlands
    Thanks lads,was going by the Haynes book,no mention in there about inserting key in ignition,just into door lock ah well typical Haynes half a job.
  1. Air-con mystery
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 16:32
  2. History Mystery
    By bigmac in forum General Chat
    Last Post: 8th June 2011, 11:50
  3. A bit of a mystery
    By watchman in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 06:44
  4. mystery pic......
    By david.aka.judas in forum General Chat
    Last Post: 18th July 2010, 22:07
  5. A Great mystery!!
    By MLC in forum General Chat
    Last Post: 9th June 2006, 18:48
