Thread: engine missfire diesel
    south wales
    Default engine missfire diesel
    hi all for a couple of weeks now ive had trouble with my headlights flickering, when driving they flicker loads and are quite dim on the road, when static the engine has a slight miss and when looking at the clock on the dash it goes dim then bright then dim, i think its a miss in the engine but dont know where to start to look
    dont know if this is common
    any ideas? car is a 54 plate 1.9 cdti 8 valve
    ps sorry to post again in the right forum
    Bristol
    Vehicle : CDTI 150
    Hi,
    You could have 2 issues.
    Firstly the flickering headlights are probably due to an issue with the alternator (this is fairly common), but check the drive belt and tensioner for wear.
    As far as the 'miss' goes, could be caused by the volts drop or sticky injector.
    Once you've got the problem with lights sorted try running some injector cleaner through.
    Hope this helps
    Regular Member Innes's Avatar
    Plymouth
    It sounds like you are running out of electricity. Either you alternator is playing up or battery has come to the end of its life. When was the battery last changed?
    south wales
    battery not changed while ive owned car so last two years really and the lights only really flicker when im driving weird
  1. diesel engine re map
    By tyler boy in forum Diesel Engine related
    Last Post: 20th September 2011, 09:34
  2. Diesel Engine Oil
    By John Bishop in forum Vectra C / Signum Troubleshooting
    Last Post: 31st May 2011, 14:59
  3. Which diesel engine??
    By cornishtaz in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2010, 17:39
  4. which diesel engine?
    By Pigman1 in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 22:59
diesel engine missfire
