Thread: Button led change with solder glue
    Regular Member 111's Avatar
    Stockton-on-Tees
    Default Button led change with solder glue
    Would anyone use this instead of solder to avoid heat damage to the PCB http://www.smallbattery.company.org...._wire-glue.htm there is no pressure like on a remote micro switch so would it be alright, may try it on one. so next question- are the switches programed to to ecu like on a volvo? as I can't afford to have to buy a new switch and have it tech2 to the car.
    milton keynes
    what switch are you looking at doing?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Funnily enough my factory SMD's were soldered and glued to the PCB when I did my conversation on the door switches, pain in the rear I must say. I melted part of my drivers door switch and just replaced it from ebay. It was plug and play for me but couldn't tell you about a full can set up.
    Stockton-on-Tees
    Quote Originally Posted by kman247 View Post
    Like the ones you have,
    Door window switches 1st then others depending on how they go.
    milton keynes
    Quote Originally Posted by 111 View Post
    I would say no to that then , just solder it , but use the right soldering iron ( you need to use the right iron to take them off too) , that stuff will be ok for a temporary repair or maybe joing wires , but I wouldnt use it on a PCB , especially near plated through holes incase it doesnt expand at the same rate as the tracks.
    Stockton-on-Tees
    Fair comment & thanks, just wasn't sure about my soldering skills
  1. Solder
    By beat275 in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2012, 21:18
  2. Just attempted to solder an LED !
    By john506 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2011, 23:49
  3. No solder- glue?
    By Reevo in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2010, 21:21
  4. How the hell do you solder...
    By Dan_BlackSRi in forum The 'Off Topic' room
    Last Post: 2nd April 2009, 10:32
