Thread: flickering lights when driving anyone had this prob?
    south wales
    Default flickering lights when driving anyone had this prob?
    hi all for a couple of weeks now ive had trouble with my headlights flickering, when driving they flicker loads and are quite dim on the road, when static the engine has a slight miss and when looking at the clock on the dash it goes dim then bright then dim, i think its a miss in the engine but dont know where to start to look
    dont know if this is common
    any ideas?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    maybe alternater (cant spell so dont tell me lol) is on its way out?? as not put enuff power in battery to run lights?? is it petrol or diesel??
    south wales
    its a 1.9 cdti. it had a new alternater this time last year, surley cant go again that quick? but it makes sense i might just check the connections thanks
    Sep 2010
    in a box
    just a quess m8 if im honest but try it get back to us
    south wales
    had a look at the connections to alternator they all seem to be tight, with an engine miss on a diesal what could it be because ive noticed its the whole electrics that seem to skip a beat, could it be a glow plug on the way out or a blocked injector? i dont know
    any help please
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    wouldnt be the glow plugs, theyre only used when starting the engine. personally i would check the battery is ok before going for the alternator, it may be at the end of its life. i am having a similar thing on my 2004 1.8 LS, lights all over the car dim when i turn the steering wheel, which is normal to some degree, but noticed it more recently. as for the misfire on a diesel, bit beyond my expertise, someone else on here should be able to help there. as for the dim headlights, you still using halogen bulbs? get yourself some HIDs, you wont regret the improvement.
    Regular Member Innes's Avatar
    Plymouth
    It sounds liek your battery may be coming to the end of its life. When was it last changed?
  1. Lights Flickering
    By Alan/1967 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 14:20
  2. Lights Flickering
    By Chris SRi in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 22:59
  3. Flickering Lights
    By jamesyoumans in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2010, 22:04
  4. Lights Flickering?????????
    By shadow-irl in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2009, 10:24
  5. lights flickering
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2008, 01:57
