Thread: which fuses do i need to check?
    Oct 2010
    hull
    Default which fuses do i need to check?
    Over the last week or so i have installed an aftermarket double din.
    The first time i connected the harness to the iso i got a tiny spark from the harness end of the connection. At first i thought nothing had happened and was just one of them things.
    As it stands at the minute......
    1. the abs light is on
    2. the steering is heavy and on the light is on where it is a steering wheel with a ! on it.
    3. the speedo does not work and the trip disdance under the speedo cannot be reset my pressing the button.
    4. On the infotainment screen, a few of the options have an "F" instead of the relevant info. ie. " F Miles "
    im going to start by checking the fueses but im unsure of which ones to check and which location they will be on the car.
    just after a few pointers.
    thanks, chris
    Regular Member Dazzy2006's Avatar
    Notts
    Dashboard may be a cim issue but check fuses F17 & F26 on the passenger side
    abs light - might be worth checking abs plug on the front calipers
    Power steering - maybe the pump or something to do with the cim but its bust and needs fixing
    If fuses are ok best bet is get codes read as the cim and power steering pump are mega expensive
    Is your stereo all sorted now?
    Oct 2010
    hull
    yeah stereo is done thanks alot, needed to go to fag lighter in the end. i hadnt had any of these problems until i started changing things so im thinking it cant just all fail all at once surely.
    Notts
    Quote Originally Posted by chris167 View Post
    It's a vectra so it probably can , the cim controls most of it so double check those 2 fuses are perfect ( might even be worth replacing them just to rule them out) before getting codes read as i'm sure the cim is around £400
    Oct 2010
    hull
    thanks ill have a look in morning then
  1. Fuses
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2012, 00:50
  2. Boot lid wont open - What fuses to check??
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2011, 21:59
  3. 12V fuses
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 20:57
  4. What are all the fuses used for?
    By TheWildHaggis in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 18:44
  5. Fuses
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2007, 17:06
