Thread: P1109 fault code after alternator replacment
    Nov 2010
    CHIGWELL
    Engine : 1.9 cdti (150)
    Mileage : 88000
    Default P1109 fault code after alternator replacment
    Hi Everyone.Car wouldn't start Monday morning.Towed into local garage.Alternator replaced on advice of recovery truck and garage.Garage tell me there are two alternators for my car so they have to check which one I need as they are different voltages.Within 2 minutes of leaving garage after work done, car goes into limp home mode.Garage look at car again reset it, turbo now working again,but now say it has P1109 fault code.Could garage have fitted wrong alternator? Could they have caused the fault when doing the alternator change as have never had the problem before? Last time I did any diy work on a car it had carbs not a computer.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Or it could be the throttle position sensor in the throttle body? Are there no other fault codes? P0638?
    A car that can't start and assuming the ignition and fuel system is fine then it leaves one culrpit imo - the throttle flap. This could be shutting over for some reason - usually due to an open circuit. Make sure they are satisfied which ever one it is. I had the throttle pedal replaced but it made no good. The fault actually lay in the Throttle body.
    http://www.vectra-c.com/forum/showthread.php?t=118784
    Gazza4
    Nov 2010
    CHIGWELL
    Mileage : 88000
    They didn't tell me any other code or sub codes.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by knfruitbat View Post
    Earlier CDTI's had an issue with the throttle pedal. Fault code P0638 - if the problem is what I think it is - will be there, but you will need Op-Com or Vaux-Com to find it as it won't be an active fault - just intermittent.
    Gazza4
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    p1109 swirl actuator malf lift off top cover have a look at rod on manifold if its on start eng should move accross if not could have a fuse blown or its seized .
    durham
    the fuse you need to check is fe14 in box under bonnet
  1. P1109 Error Code
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:49
  2. fault code for alternator problems
    By mace in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2011, 21:46
  3. Fault Code P1109
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 20:53
  4. Fault Code P1109
    By SSM in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 11:56
  5. P1109 fault code
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2009, 17:35
https:www.vectra-c.comforumshowthread.php122901-P1109-fault-code-after-alternator-replacment
vauxhall code p1109
vectra c p1109 fault code after cleaning throttle body
p1109 vauxhall malfunction
p1109 code
vectra 1.9 p1109
vectra 2006 changed alternator car in limp mode
vauxhall fault code p0638
fault code 1109
p1109 vectra 150 sri
fault code p1109
vectra c alternator fuse
