Well thanks to a previous post on here I found the blocked drain just under the pollen filter, however I cant see where to spray wd40 on the fan to help stop the rust, could anyone help out?
Remove the Pollen Filter and then you can see the top of the fan and can check how free it is by turning it by hand.
Don't use wd40 as its not a very good lubrication spray, more of a release agent. Try something like 3in1 or even engine oil - new of course.
I believe scilicon spray is best
Use whatever has the least smell - otherwise you'll be smelling it in the car whenever you turn the fan on.
Found this on another thread which should help.
http://www.vectra-c.com/forum/showthread.php?t=108462
WD40 well got rid of the squeak I had on my heater/aircon on my last car.
