Thread: Air con problems
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Air con problems
    My aircon has never worked isnce i got the car in july, now going through summer that was a ***** but id like it fixed now even though it wont get used for 6 months...
    Basically if you press the button it lights up but no cold air circulates. infact no air seems to on behalf of the aircon.
    Furthermore a light rasping noise may be heard as if a light-metal fan was catching at one point in its rotation, any ideas?
    If your not going to use it for 6 months then there is every chance any gas put in the system may escape again. I'd leave it until next april time unless you plan to use it for demisting in the winter months. The manual says you should run it for 20 mins a month or so all year round to keep the system in good condition.
    if there is no pressure in the system then the car won't let the compressor run.
    Nov 2010
    UK
    so there must be pressure in the system then?
    I'll try leaving it on whilst i travel home over xmas then and see if it activitates at all!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    That was take on it too.
    Does the compressor engage and start rotating when you press the button for A/C?
    Quote Originally Posted by Thom View Post
    Yes it must see a pressure or the ecu won't let the compressor engage. If its working you will hear it cut in and out.
    Nov 2010
    UK
    Yes, but nothing comes out except the sound of a rotating part.
    Pardon my technical ignorance!
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
