Thread: Problems starting 2.2 petrol in cold
    Aug 2010
    Here
    Default Problems starting 2.2 petrol in cold
    I've started getting a problem where my car, 2.2 direct injection petrol, doesn't start when it's a cold day - usually when the temperature drops below 5 degrees C.
    There's a clicking noise from under the bonet but thats it. As soon as the weather warms the car starts first time. I've had the battery checked but I've been told it's ok.
    Has anyone else come accross this problem in the past? I can't understand why it's only the cold that seems to be affecting this as a starter motor problem would cause problems in all weather not just cold wouldn't it?
    Unfortunately the Haynes manual for my Vectra doesn't come out til the end of this month!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Mine did this. Checked the battery and it was fine. Upon further inspection I realised the battery was too small. New correct battery and no problems since.
    Aug 2010
    Here
    Thumbs up
    Thanks Rushy.
    I checked the battery and it wasn't the GM one. When I looked at it it was a 60A one. I checked the recommended size for my car which is a 70A.
    I've fitted a 70A battery which is at full power and I've had no problems since. Thanks for the advice
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    wow another one to Rushy nice one mate
    Dec 2010
    liverpool
    hi there got same problem my self got a elegance 2.2 53plate auto .
    checked battery and i have the 66ma vauxhall so now 2 questions is this correct battery and is there any other fault this could be . cheers
  1. petrol/lpg cold starting
    By murt690 in forum Engine & Drivetrain
    Last Post: 4th February 2013, 21:52
  2. 2006 1.9cdti Cold Starting Problems
    By rjcotterill in forum Engine & Drivetrain
    Last Post: 7th June 2011, 16:15
  3. 1.8 Petrol engine starting problems
    By Rallyingden in forum Engine & Drivetrain
    Last Post: 8th September 2010, 09:35
  4. Cold starting problems!
    By tony750cc in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2010, 00:41
  5. Starting cold Problems
    By vectraspain in forum Engine & Drivetrain
    Last Post: 13th April 2007, 18:23
what is the cause of cold start in zafira 2.2 petrol
lack power when its cold zafira 2.2petrol
https:www.vectra-c.comforumshowthread.php122426-Problems-starting-2-2-petrol-in-cold
