Results 1 to 10 of 18
Thread: Dual mass flywheel destruction!? (DMF)
    Oct 2010
    north wales
    Default Dual mass flywheel destruction!? (DMF)
    Ok guys, another DMF question.
    Let me ask first if it is what i think it is....
    Start the car as usual, then i depress the clutch about 1inch then the noise (tucker tucker tucker) like a ratteling roatating noise. Then i press it all the way to the floor and it stops. Bring it back up anf the noise starts again, then if i take my foot off nothing...
    Ive done plenty of searches on the DMF, but a few question i dont think were asked.
    Firstly if it is what i think it is, what exactly will happen? "Peope say oh the DMF has gone that guna cost you!" So will it just keep making that noise or will it eventually fail resulting in somthing bad and expensive?
    Next, has this problem been rectified? Is it a fault with the fly wheels or clutches? or what? because if i do need to fix this then i want to replace it with the latest remedied part (if it exists)
    Also, how much is it going to cost? (on average) I might have a go if its not too tricky....
    I know thats a lot to ask but any advice will be most helpfull!
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    m8 dmf has gone id say and more you use it the harder it will to get it off( they spin and you need disc cutter to get to the bolts they spin and cover the bolts only way to get to them is cut the dmf) dono if leavein it will make it go boom as to like ****ing your gear box ect and as for doing it your self you need a ramp and like 2 people min (gearbox is one big *****) would never try this on the floor unless you can bench press 200kg as thats wat gear box feels like to pick up lol (ok it ent 200kg but i bet its a good 70kg but bench presing a lot harder then just lifting something and cost £700+ thats evertthing clutch dmf ect hope that helps
    Regular Member signumturbo04's Avatar
    SCOTLAND
    i done my clutch and dmf in my driveway took me 4 hrs. not that difficult to do and i got clutch kit and flywheel for £500 inc vat
    Oct 2010
    north wales
    4 hrs not bad i guess when you think how much i could save.
    I guess it must be it then. Pay or do it myself. unless its stuck on solid.
    Anybody know which would be the bast part to buy, like luk or gm or another better product?
    Thanks Alex
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Hi mate as a 2007 member Ive read lots about dmf, but never really drove other vecs with or without the fault!, well i did this week, 07 cdti wih no dmf problems! & smooth to drive, My cdti 150 04rg 65k has slight rattle, has done for some time, has got slightly worse with giving it Boot!, plus my main question as a similar case is Do you or have you noticed any slight vibration when accelerating ?, I'm trying to pinpoint mine but as I'm fairly busy & only using it sat or sun i cant remember if its always been there or just me being paranoid, hows yours.
    DERBY
    the dmf failed on mine , the LUK part is the same as vauxhall part , vauxhall quoted me £1000,total £500 to fit ,£500 for the part , went to a local garage £350 for the part £350 to fit , had it in for two years now and touch wood , mine failed at 33,000 miles, big job to do on the floor as box has to come out
    Birmingham
    I had the exact same problem on my 54 plate 1.9 diesel. Needs a new clutch and flywheel costing a total of £720!
    Oct 2010
    north wales
    Quote Originally Posted by Simonvectra View Post
    Did that include labour?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    mine went on my old 1.9cdti parts cost £500
    laour cost £80 cash in hand at local one man band garage.
    Bristol
    Vehicle : CDTI 150
    Mine cost £150.29 for new DMF and clutch with CSC fitted.
    Mind you I had taken out an AA warranty when the Vx one expired, also covered a new alternator fitted for £25.
    Best £440 (£18.34 a month for 2 yrs) I've spent as the warranty still has 19mths to run.
  1. Dual mass flywheel help
    By Garuk in forum Engine & Drivetrain
    Last Post: 14th October 2011, 14:30
  2. dual mass flywheel.
    By blacksricdti in forum Engine & Drivetrain
    Last Post: 17th December 2009, 18:28
  3. What is a Dual Mass Flywheel?
    By s0501291 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2009, 23:31
  4. Dual mass flywheel
    By 900ss in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 24th January 2009, 17:47
  5. Dual Mass Flywheel?
    By Gascon in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2008, 21:44
