Thread: Lost time on MFD how do i reset?
    Oct 2010
    Northamptonshire
    Default Lost time on MFD how do i reset?
    Evening guys, just a quick question.
    I've fitted an alpine headunit to my prefacelift sri and this has reset the time to 0:00. I have no buttons to use to set the time. Im guessing it grabs the time from the oem cd unit. Is there anyway around this? Can i set it manually some how?
    South West
    Nope.
    Two options:
    1. Put the OEM headunit back in, and RDS will reset the clock
    2. Tech2. Vx can do this, will probably charge you for this.. but they might be kind if you ask them.
    Rgds
    Aidi
    Oct 2010
    Northamptonshire
    Cheers mate.
    So it i bang the oem unit back in and set the time and then remove it will it remember it?
    Tech2 will cost silly as vaux are crap here.
    Regular Member lewcdti's Avatar
    Oct 2010
    South Wales
    Pretty much matey. Although if you disconnect the battery after the time has been set via RDS it will reset to 0:00.
    So put the OEM unit back in, fire it up and tune to radio1/2/3/4, let it grab the RDS signal which'll set the time, turn off ignition and remove the OEM unit, fit the aftermarket unit, and then the clock should remain set. HTH.
  1. ECU reset
    By wilson002 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 19:15
  2. Sat nav reset.
    By welshboy in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 03:12
  3. ECU reset
    By Netstar in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 15:14
  4. ECU Reset ????
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 14:36
  5. ECU Reset
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2007, 13:35
