Results 1 to 10 of 13
Thread: Clutch Thrust Release Bearing Perhaps.?
    Birmingham
    Question Clutch Thrust Release Bearing Perhaps.?
    Hi all, Without touching the gearstick at all, If i depress the clutch pedal about an inch i get a rattle sound where the bite would normally be. If i then depress the pedal to the floor the sound has gone. The car (Vectra 1.9CDti 150), is on an 06 reg (4.5 years old) and has only done 35,000 miles.
    Is this the thrust release bearing.?
    Will i have to have the whole clutch replaced if it is.?
    Is it covered under warranty with only 35,000 on the clock.?
    How much roughly will it cost.?
    Regular Member se4's Avatar
    Aug 2010
    wales
    sounds like the flywheel to me fella, time to dig deep into your pockets
    Oct 2010
    N. Ireland
    I have heard these flywheels/clutches can rattle like that for years before they finally give up. Is there any way of knowing when there about to go, think it depends on how they are driven.
    Aug 2010
    Leeds
    They get louder then explode the it's dead.
    Seriously id put up with it till it develops, But do start saving your cash.!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by melvin View Post
    Mines has been rattling for 85k/4 years.
    Gazza4
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Just leave it mate. Listen to me and Gazza4
    Jun 2009
    notts
    my wifes signum has just started doing the same thing, raffle noise and slightly judderly at slow speeds.
    How much for new clutch,flywheel,fitting?
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Quote Originally Posted by raddish View Post
    Main dealer up to £1300 Vauxhall independent garage £700-800.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Vx will quote £1,500 but I would search the internet for some specialist clutch/flywheel/transmission specialists.
    Hairy31 on this site got his done for £700 but I am not 100% if the clutch was included.
    Gazza4
    deanos
    Guest
    Mine was £740 inc flywheel and complete clutch at a VX specialist in Lincoln recently
    I doubt you will get it done under warranty at nearly 5 years old.
    Its worth doing the clutch at the same time IMO while all the gearbox is out as you would be paying for the labour again if the clutch went, then again you have only done 35k on it
  1. clutch release bearing
    By martin_SRI in forum Engine & Drivetrain
    Last Post: 20th December 2010, 21:37
  2. clutch release bearing
    By pizzajazz in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 17:36
  3. Clutch release bearing help 3.2 GSi
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 29th June 2009, 10:52
  4. 3.2 GSI Thrust/Clutch bearing Question.
    By gsi32 in forum Engine & Drivetrain
    Last Post: 4th February 2009, 13:45
