Thread: Double DIN into my Vectra
    Regular Member Rorschach's Avatar
    Jul 2010
    Midlands
    Default Double DIN into my Vectra
    Right, I've took the plunge and bought a JVC KW-XR811. I was after something that looked factory, yet was a Double DIN and not a DVD player.
    I've only owned my Vectra since August 2010 so this whole canbus do-dar is completely new to me. I've only just received the CD player, and realised that you don't get a lot with new players any more. Connection-wise, the player came with a standard JVC > ISO wiring harness. Here's my problems:
    - I currently have a CD30, in a 2007 SRI full canbus vehicle. Do I require a connector like below, or are there other parts that may be needed?
    http://www.caraudiodirect.co.uk/prod...oducts_id=8022
    - I'm looking to get a Fascia adapter, but they're showing as being in the region of £40 for double don (admittedly, you get a cage with it also) however, I'm quite confused which colour I'm supposed to get and if that cage is really necessary. I have the standard Dark Grey Vauxhall dashboard similar to below. What would be the specific term for the colour? I'm at work at the moment, having a cheeky browse
    The Double DIN Kit
    http://www.caraudiodirect.co.uk/vaux...nthracite.html
    The colour match
    (thanks to vectra_c_wannabe for pic)
    Thanks in advance to all that reply.
    Regular Member Dazzy2006's Avatar
    Notts
    when i fitted my double din stereo i had to buy a connector but mines half canbus so im not sure in your case, as for the fitting kit - yes you will need 1(even though u wont use all of it) and your dash looks the same colour as mine which is charcoal mettalic but if u slide your radio out the colour is stated on top of the radio.
    I decided to use a black facia as my stereo is black and i couldnt find a charcoal mettalic facia but there are a few different grey ones
    Jul 2010
    Midlands
    Thanks for the reply Daz. I've just found this...
    http://www.dynamicsounds.co.uk/autol...r-p-23801.html
    Apart from the colour match which I'm yet to confirm, does it look like I could just get this and attempt to use the cage that came with my stereo?
    Notts
    Nope - i thought the same as my double din came with a cage but it wont fit the facia , seems a total con but u will need the whole fitting kit including new cage that u linked to above
  1. Double Din for my Vectra
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 14:17
  2. Double Silver Vectra Spot
    By Happy Girl in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 11th August 2011, 18:39
  3. double din in vectra
    By sclarkson82 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 12:50
  4. Double Din Facia - ANy of These Suitable For A Vectra C 07 ?
    By ccsnet in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2008, 18:14
