Astra Mk4/G Headlight Switch (1998 - 2004) !
I have for sale a Vauxhall Astra Headlight Switch.
I bought this from a scrapyard about 3-4 months ago as I thought my one was faulty.....turned out to be a dodgy fuse/relay (so the garage told me). Anyway, this has been sat in my garage since so it may as well to good use.
I havent actually tested this but I have no reason to suspect any fault as the car was pretty clean that it came out of, just had a dodgy engine. It was removed from a 2002 Vauxhall Astra LS which DID NOT have front fog lights.
This unit is in good condition. May suit other ASTRA-G's, but IF it suits your car is up to you to check, I can only tell you what I read from other adverts.
I have described this unit to the best of my ability so please ensure you accept everything stated and then make an informed decision about whether or not this item is for you. It will be sold as seen.
!!! What you see is what you get so please ensure you examine the picture and are aware of what you are buying !!!
£6.50 POSTED
