Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: EGR valve update
  1. #11
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by AntSSSS View Post
    This is really starting to anoy me now that I cannot fit even the big plate without the EML straight away!!!..
    I have a new Inlet and would love to fit this (both of them) - DAM!
    How can I get this sorted as I am sure its related to the Software... grrrr
    Still no problems with mine - have you thought of making the gasket holes slightly bigger (bit at a time) to gradually increase air flow through the EGR - it may work!
  2. #12
    Regular Member lofty's Avatar
    Sep 2007
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Put mine on today too and have to say.. makes a big difference lower down the revs
    All for a £5 and ten mins work.. bargain!
  3. #13
    Jan 2007
    Swindon
    is there any pictures around to show how to do this. after just shelling out £695 for a new inlet manifold, due to swirl valve issues, i'm keen to stop this happening again.
  4. #14
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Trim : Elite with sports pack
    Engine : CDTi 150
    Mileage : 103000
    The last post on this Saab forum post may help CLICKY
    fitted mine today after an EGR clean. Threw the P0400, so I drilled the holes out to 10mm. Still threw the code, so I am now trying with a few more holes. Hope it isn't the valve
    Ok, drilled three 5mm holes strategically in it and.... we have a winner, it seems to have brough it inline with what ever the tolerence is.
    No noticable difference to performance other than down to the fact I have a clean egr.
  5. #15
    Sep 2007
    @home
    Engine : 1.9 CDTi
    Just a little tip for anyone who is fitting this (although you'll all probably figure it out)..
    There's a bit of the gasket that sticks out so put this at the top, that way if you remove the egr you can keep hold of the gasket so it doesn't fall down into the engine.
  6. #16
    Regular Member djr69uk's Avatar
    Feb 2008
    Midlands
    probably been covered a million times so slap me for being lazy... but what are the part numbers for this?
  7. #17
    Mar 2007
    Southport
    Quote Originally Posted by djr69uk View Post
    Fiat P/N 55225287
  8. #18
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Just to update, I have just been to buy another of these gaskets (as I lost my other ) and they have updated it to part number 55226183 which is a single gasket (proper gasket, not a flat piece of metal) and the tidy sum of £2.40.
    Just to re-iterate, this gasket is for the 120 CDTi EGR system (but fits to the exhaust side of the 150 EGR).
  9. #19
    Sep 2007
    @home
    Engine : 1.9 CDTi
    oooh... looks like I need another gasket
  10. #20
    Mar 2007
    Southport
    Quote Originally Posted by Dan_BlackSRi View Post
    Are you using both gaskets?
  1. dump valve update after a week
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2011, 08:31
  2. 4 months on after the New EGR Valve was fitted - update
    By Vaux-Man-G in forum Diesel Engine related
    Last Post: 30th September 2010, 19:52
  3. Replies: 17
    Last Post: 15th December 2009, 14:53
  4. Power Loss Update! No new EGR valve needed (yet!).. all coz of Vectra C.com!
    By nickyg in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2008, 18:22
  5. egr valve update!
    By littlesxi in forum Diesel Engine related
    Last Post: 18th March 2008, 22:13
fiat 55225287
