Thanks Thanks:  1
Results 1 to 2 of 2
Thread: battery not charging looking at removing alternator
    Jul 2021
    Uk
    Vehicle : Vectra 3.0 cdti
    Trim : Sri
    Engine : 3.0 cdti
    Default battery not charging looking at removing alternator
    Z30dt battery is going flat whilst driving used multimeter when idling its less than 12v.
    has anyone managed to change their alternator themselves without using a garage ramp?
    got any helpful info on changing alternator I looked up workshop manual it’s talking about removing the engine subframe, catalytic converter removed exhaust off the list goes on
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    all you need is enough space to get under the car, so a good trolley jack and 2 axle stands are more than enough to sort it out. And they are right you need to remove all of that to get to it...
  3. Thanks delcbr thanked for this post
  1. When charging your battery without removing it....
    By FatboySteve in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2017, 20:09
  2. Alternator charging
    By birdii in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2015, 14:10
  3. Battery not charging. Alternator???
    By 123rado in forum Engine & Drivetrain
    Last Post: 12th May 2013, 14:18
  4. battery light on, alternator not charging, aarggh!!
    By valvelift in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 17:33
  5. Alternator not charging?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2011, 13:15
