Results 1 to 5 of 5
Thread: Air con
    Jan 2010
    telford
    Default Air con
    Don't no if this is right section but I have a problem with my air con it doesn't cum on when I press the button in the car but I have bypassed the wireing by going direct form the battery and the clutch engages when I do this so think it might be some thing else also there is no gas in the system for sum reason can anyone help me on what they think is is please
    Jan 2010
    telford
    Anyone any ideas
    Regular Member gsroute's Avatar
    Feb 2013
    Scotland
    Trim : SRI
    Engine : Z18XER
    Year : 2008
    If there is no gas then it wont turn on to protect the compressor.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    It doesn't turn on if there is no gas in the system. Most likely its a hole in the condenser, but it could also be a seal thats failed due to lack of use. AC systems need to be run for at least 20 mins a month to keep the seals from drying out. Go to kwik fit get them to recharge the system, if it doesn't hold the charge they wont charge you for the service.
    Jan 2010
    telford
    Thanks I will go kwik fit to moz my mate works for them so get him to have look
vectra-c
