Results 1 to 10 of 11
Thread: can anyone help PLEASE
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    Default can anyone help PLEASE
    i did that system check with the brake and accelarator because my car running ****.heres what come up.
    1.throttle body service required
    2.throttle control systrem backup system perormance
    3.ic output high/pulse detected when gnd-cyl 5
    4.secondary air injection system bank 1
    5.electric variable orifice output.
    1 is obvious but the rest????????????????????????????????????????????.c an anyone help in explaining the rest.cheers luke
    Aug 2009
    Quote Originally Posted by luke.oldham View Post
    2.vechicle speed sensor (vss circuit)
    3.ignition coil 2 control circuit
    4.exhaust gas recirculation system valve 3
    6.exhaust gas recirculation (egr)solarnoid circuit
    7.vechicle speed sensor range/performance
    8.cruise control power management mode
    this is the right list. Cheers luke
    north east
    Id get the codes cleared run the car then see whats actualy being reported :-)
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You need someone in your area with op com!, Read them & clear the 'not present' codes & have a look into the 'present' ones.
    Aug 2009
    can i wipe the codes off by disconnecting the battery.if so ill do that and see what come back on . cheers luke
    Aug 2009
    Dec 2010
    London
    8 Post(s)
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Quote Originally Posted by the-wizard View Post
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If you have the radio code you have nothing to loose!, Any 'present' faults will still be there with their codes stored, anything not present may clear but its not always the case. Leave disconnected for MORE than 1/2 hr.
    Aug 2009
    cheers mate ill give it a try. luke
    Aug 2009
There are currently 3 users browsing this thread. (0 members and 3 guests)
