Results 1 to 10 of 14
Thread: Radio fuse!
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    Default Radio fuse!
    Evening all.
    Fitting my new radio today, appear to have popped a fuse. I can't for the life of me find the VX user manual to tell me where the fuse is. Had a search but can't find it.
    Anyone able to help?
    Regular Member Handyandy-UK's Avatar
    Mar 2009
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The manual he say :
    Radio - Passenger fusebox - fuse 1 - 20A - left strip of fuses, top fuse.
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    Cheers for that. That fuse is fine, so is the one on the radio, and the new radio works fine off the Halfords testing thing.
    I'm now stumped. Any ideas?
    Mar 2009
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Check power from the cables themselves, both perm live and ign live. Beyond that I think I'd be pretty stumped too.
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    I have nothing to test power with, other than the old radio, which I can't get back into the old ****** cage.
    Just a thought, I can swap the red and yellow wires over on the loom, there's connectors built into it to do it. Would this be the problem? There's no power at all to the radio even with the engine running. I don't know if this will cause damage to the car or radio though if the wires are already the correct way round.
    Currently they're red to red and yellow to yellow.
    Mar 2009
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I would stop right there.... too much expensive electronics to risk swapping things around without knowing what's hot and what's not. Whizz off to Halfrauds or your local motor factors and get yourself a small multimeter - will save you a fortune on all manner of jobs.
    Such a device will not only allow you to check for power, but also fully check the fuses - you'd be surprised how many look fine visually, yet have actually blown.
    Feb 2010
    Wirral
    10 Post(s)
    Trim : Design
    Engine : 1.9CDTi
    Mileage : Lots
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH.
    I'm going to throw it out the window. It doesn't make sense! Have another go tomorrow.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Vehicle : Vectra C
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    when i fitted my stereo i was going mad i thought i got done over because i brought it from china and it didnt work it took me 30 mins to figure out why,
    your right
    cut the yellow and red wire in the middle then yellow to red and red to yellow, mine worked after i done that
    Regular Member Exclusive BV's Avatar
    West Midlands
    I seem to remember having to swap yellow and red on an older vauxhall but i confirmed them at the time using my multimeter.
    For a tenner off the market they are invaluable and dont need to be that accurate either for small jobs
    Regular Member lochgilp's Avatar
    Mar 2006
    argyll
    if i remember swapping the red and yellow is only something to do with keeping the memory settings on your stereo, check the cigarette lighter fuse which i think is a 30 amp cause have have to connect to that when u fit an aftermarket stereo if i remember correctly hope that helps mate
  1. Fuse fe1
    By Tombird in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2013, 22:05
  2. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  3. help fuse box
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2011, 19:24
  4. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  5. Radio fuse blown?
    By beachlife in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2007, 19:26
vectra c radio fuse
vectra c stereo fuse
https:www.vectra-c.comforumshowthread.php125278-Radio-fuse!
vauxhall vectra c radio fuse
vauxhall vectra radio fuse
vauxhall vectra stereo fuse
radio fuse vauxhall vectravectra c radio fuse locationwhere is the radio fuse in a 2005 vauxhall vectraVauxhall vactor radio fuse what number. Where 2004 vauxhall vectra radio fuse2007 vectra c radio fuse location where is the stereo fuse on a 2004 vectravauxhall vectra 2005 radio fusevectra c car stereo fusevectra c fuse for radiowheres a vauxhall vectra c radio fuse vectra life stereo fuse locationfuse for stereo on vauxhall vectravectra c fuse box radioradio fuse vectra copel vectra c radio fusevectra radio fusehow do you change the stereo fuse on vauxhall vectra 05vectra c stereo fuse location
