Results 1 to 4 of 4
Thread: can anyone help
    Regular Member denzilbud's Avatar
    May 2009
    cambridge
    Default can anyone help
    hi all havent been on for ages as i started a new job and been working hard,anyways my prefacelift z22se has started using loads of fuel so much so im thinking or getting rid,the car takes ages to get up to temp and the heaters arent as warm as they used to be also on long journeys the emission light comes on then goes off after a couple of days of round town journeys,im thinking the emissions light is down to a faulty lambda but would it be a good idea to fit a new coolant temp sensor or a thermostat to cure the temp issues.
    Regular Member ant6566's Avatar
    Feb 2010
    gwent
    i would start with a thermostat,as in my experience of previous cars this is mostly to blame.alternately,start with the cheapest or easiest part to deal with.
    Regular Member Dazzy2006's Avatar
    Notts
    iirc doesnt a faulty lamda sensor cause overfuelling which would explain why your using so much fuel ??
    As for the temp, as ant says start with the thermostat and go from there
    May 2009
    cambridge
    cheers for the replys
