Hi all,
Some may remember I had a slow puncture in my front nearside wheel and when I finally took it in to have it repaired they found two cracks
Looks ok....
Still looks ok....
Look closer.....
And here....
****** I thought....
So I did a bit of tinterneting and came accross these guys...
http://www.fawheels.co.uk/
What a decent bunch... Peter is the main man and he completely cut out both fractures and filled/welded new alloy in. Then he machined the inner lip so there was a good seal for the tyre and left the weld proud on the outer edge for strength.
He also straightened out a slight buckle in the wheel and repainted the repaired areas. The whhel was fully masked up so no dodgy over spry etc.
Tyre refitted using rim guards and fully balanced needing only a 10g weight. £70
End results....
and the other one....
Jon
