Hi all,
Having read a lot of posts regarding misfire on the vectra cdti's i still cannot cure this problem of mine .
It all started approx 6 months ago, when pulling away from junctions, roundabouts etc, i get the occasional split second cough (would'nt say misfire) sometimes it does it every couple of miles then sometimes it will run a week without doing it!! It is fine if you boot it all the time!!
Heres what has been done recently:
New EGR Valve
New manifold & swirl actuator,
New Fuel Filter,
New Air Filter,
But still to no avail,
Can the No.3 injector wire cause just a split second cough like this,
No codes are present using the snap on solus pro & sykes pickavant acr4 G2 suite,
My last resort is to send it to the dealers to see if they can find it using tech2 but i hate the idea of paying £60-£70 for them to say it could be this, could be that etc, (you know what i mean)
Can the accelerator pedal sensor cause this as it always seems to be when the pedal is in a certain position!
Seriously thinking of getting rid, but it's such a nice car except for this little hiccup now & again,
There is a slight rattle from the Dual Mass flywheel (could this cause it??)
Any help greatly appreciated!
It is a 55 plate vectra cdti elite 150
Thanks.
Dave.
