Thread: Calliper Removal
    Fareham, Hampshire
    Default Calliper Removal
    hi there i have had a few problems with my rear offside calliper sticking, after many times of removing it from the carrier and freeing it off i am getting to the point now where it needs replacing.
    I have had a look at it and i can see that the brake line needs removing which seems easy enough however the handbrake cable....... i cant see how to remove the handbrake cable, does anyone know how to do this.
    its on a 1.8i 16v club vecrta c.
    anyhelp would be greatfully received, many thanks Bogz2000
    Fareham, Hampshire
    bump
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Untill I get home I cant help mate. Bump it again later nearer 5pm for when we start getting in from work. I belive there is a kit to service the caliper. It's usually the slider bolts that stick and a good clean of them usually sorts the problem.
    Fareham, Hampshire
    will do pal thanks for the help
    Fareham, Hampshire
    bump
    Administrator plasma's Avatar
    Mar 2006
    On the Forum
    574 Post(s)
    Engine : 150
    Year : 05
    Mileage : 74000
    handbrake.. pretty easy... to remove from the caliper grab the end of the cable (flat bit near the lever arm) with a pair of pliers. pull on this until you can unhook from the caliper itself. The cable goes through a thick rubber neck set into the caliper itself. the whole rubber neck and cable come out as one piece, its bluddy tight/stiff so plenty of wd40 on that....
  1. calliper colours
    By daddyjay in forum Photoshop section
    Last Post: 29th March 2012, 21:58
  2. another calliper post
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 12:08
  3. stuck calliper
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2010, 22:20
  4. New calliper decal's
    By shan in forum Styling
    Last Post: 13th October 2008, 21:36
  5. Brake Calliper Help?
    By Digital_kid in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2007, 11:31
