Results 1 to 7 of 7
Thread: Bottoming out??
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    confused Bottoming out??
    Following on from other threads and the subject of new springs settling i` ve come to the conclusion my shockers are bottoming out.They re B4s and when i fitted them they looked slightly longer than the SRi shocks but i thought nothing of it but now the springs have settled if i hit a pot hole or bump at anything above about 20mph the bang is harsh to say the least.Is there a way of telling for sure if they are and whats the solution ( which shocks etc) ?
    Cheers
    Regular Member EURO G's Avatar
    Dec 2007
    n ireland
    same problem here mate with b4s
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    No problem with B4's and standard VX springs on the rear of mine.
    Regular Member parapaul's Avatar
    Jul 2006
    The B4 is designed as a direct replacement for the STANDARD dampers, the ones that are fitted to non-sports suspension. So yes, they are longer than the original SRi shocks but will doubtless work fine with the Vx -15mm drop.
    To match shorter springs, like Eibach, PI, whatever you use to lower the car, ideally you need the B6 which is a shorter and stiffer damper. However, instead of £40 each they're about £130 each. I'm saving already...
    Expensive hobby, this modding malarky....
    Dec 2007
    n ireland
    looks like coilovers for me anyone for my 40mm h&rs and b4 shocks
    Regular Member Kyser143's Avatar
    Bradford
    not had any probs with my b4s on a sri...will try it over a speed bump at some speed see what happens.
    I had this when i changed my struts and springs but it was my own fault as i had not replaced the bump stop i presume you have re-fitted it when you changed the struts ???
  1. Front springs bottoming out
    By bobmcn in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2012, 13:38
  2. Lowered suspension bottoming out HELP?
    By dogstar in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2009, 14:55
  3. Has anyone suffered with Bottoming by Dropping 30mm on Eibachs
    By DeanF in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2008, 21:47
