Thread: Signum front axle load ?
    Regular Member shan's Avatar
    Default Signum front axle load ?
    I was just on the phone to Roadrunner chatting about some Eibach springs. They need to know which front axle load weight rating i have.
    Is it either 1060Kg or 1130Kg.
    She has the 1.9 signum with both axle weights. Which i said is a bit strange
    Anyway could somebody check it out for me so i can order them.
    Nice lady on the phone said somebody off here ordered a set the other day. Who is it????
    Quote Originally Posted by shan View Post
    I think she's getting mixed up. On the plate on the driver's side B pillar it has two weights, amongst other things. One saying '1 - xxxx' and the other saying '2 - xxxx' where xxxx is the axle weight. #1 is the front, #2 is the rear. I know you aren't with your car, but its the #1 figure that you need somebody to check that has the same engine. I believe it's the same front axle weight on a Signum and Vectra.
    Regular Member j13hdb's Avatar
    Jan 2007
    Nottingham
    Your best bet is to wait till your hangover's gone,you get home and open your driver's door and look on the plate on the door pillar!!! The 3.2 has 3 different options and it's all about the strength of the springs.
    Have a good flight mate!
    She says in here catalouge it show's that the part no. 10-65-011-01-22 and 10-65-011-02-22 are also for the signum 1.9 " not shown on the website or this list" but as you can see they are different front axle weights.
    Same for the vectra bus.
    Thats why i said to her thats strange as it's the same engine and the same car so it should be only one.
    Vectra C1.6, 1.804.02 -965 kg980 kg10-65-007-05-22£138.00
    Vectra C1.8, 2.0 Turbo, 2.2, 3.2, 1.9 CDTi, 2.2 Dti04.02 -1060 kg980 kg10-65-007-01-22£138.00
    Vectra C2.0 Turbo, 3.2, 1.9 CDTi, 2.0 DTi, 2.2 DTi04.02 -1130 kg980 kg10-65-007-02-22£138.00
    Vectra C3.0 DTI05.03 -1230 kg980 kg10-65-007-07-22£138.00
    Vectra C Estate1.8, 2.0 Turbo, 2.2, 3.2, 1.9 CDTi, 2.2 Dti04.02 -1060 kg1140 kg10-65-011-01-22£138.00
    vectra C Estate2.0 Turbo, 3.2, 1.9 CDTi, 2.0 DTi, 2.2 DTi04.02 -1130 kg1140 kg10-65-011-02-22£138.00
    Vectra C Estate3.0 l DTI04.02 -1230 kg1140 kg10-65-011-03-22£138.00
    Signum1.8, 2.0 Turbo, 2.2, 3.2, 2.2 DTi03.03 -1060 kg1140 kg10-65-011-01-22£138.00 aLSO 1.9CDTI
    Signum2.0 Turbo, 3.2, 2.0 DTI, 2.2 DTi03.03 -1130 kg1140 kg10-65-011-02-22£138.00 aLSO 1.9 CDTI
    Signum3.0 l DTI05.03 -1230 kg1140 kg10-65-011-03-22£138.00
    It's a bit difficult to decipher all that stuff, but extra options can often add more weight to the FAW and tip it into the next range of a manufacturer's springs - hence why they have the same engine listed under two different parts and weights. The different listing for the Signum and estate will be due to the different rear axle weights of those to the hatch. The fronts are the basically same for all the models with the same engine.
    The only way to know for sure what you need is to get the weight from your car, as per my post above. If you can't wait until you get back to order them, can your good lady not get the number from the plate?
    Not a problem I'm just being impatient. I'll look at the car tomorrow when I'm home and make sure. I was just going to order them so I'd be in Saturday to take them off the courier.
    Cheers guys
    Well i'm even more confused now. I have 1-1120 and 2-1060. On the door pillar.
    I presume i'm needing the kit. Signum1.8, 2.0 Turbo, 2.2, 3.2, 2.2 DTi03.03 -1060 kg1140 kg10-65-011-01-22
    I dont know why these figure's don't match.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    ME but I have to wait 2 weeks as none in stock.......
    Jan 2007
    Nottingham
    1 will be your front axle 2 the rear mate
    On the roadrunner site it show's 3 setup's for signum.
    Front axle load.-- Rear axle load.
    1060 ----------- 1140
    1130 ----------- 1140
    1230 ----------- 1140
    This is whats getting me confused. as before mine show's
    1-1120 and 2-1060 so i thought the first one listed. and no.1 is rear and no. 2 is front.
  1. For Sale: Facelift front grill & V-grill and Signum load cover
    By gibbon7000 in forum Parts for sale
    Last Post: 17th July 2012, 19:13
  2. Where to put axle stands on front?
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 00:41
  3. Front axle load
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 16:07
  4. Front axle weight
    By LOCKSTOCK in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2008, 21:33
  5. Mixing 91 and 95 Load rating on the same axle
    By john_k_sri in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2007, 19:40
front axle weight z28net
