Hi All,
I've had this issue for about 8 months, it just scraped through the MOT.
I've looked at the injector flows and injectors 3 and 4 are flowing more than 1 and 2.
Do I need to replace these 2 injectors?
Hi All,
The issue is being a diesel, especially the z19 engine you won't get away by replacing just 2 injectors. Honestly i would send them to be rebuild but since the engine probably all they will is just replacing a few pieces and a good inner clean. Been there, done that. How much is your idle instant fuel consumption? On my old astra after i cleaned them it went from 0.7-0.8 to 0.3-0.4 on idle with a hot engine
I think it's between 0.2 to 0.3, but i have seem 0.8 and a smell of diesel, it went to 0.8 just as I got home Saturday after a 50 mile drive from my mums.
It doesn't do this often though.
If it goes up to 0.8 i would certainly send them to a refurbish especially since one of the injector crusher washer may be damaged since you smelled diesel and it wasn't from your exhaust. Don't forget to replace these 4 and the fuel filter
is it regen constantly or trying to will create smoke
is oil level creeping up on dipstick
s it could be sensor blocked in manifold giving false back pressure reading
This post requires you to click the Thanks button to read this content. This post requires you to click the Likes button to read this content.
