Thread: Weird light (and wiper) problem
    Jul 2013
    Norway
    Vehicle : Opel Vectra
    Trim : estate
    Engine : 1.9 cdti 120
    Default Weird light (and wiper) problem
    The car reports "open circuit" for a number of lights. Dipped beam left, high beam right, blinker right, one fog light, one parking light and both reversing lights. All of them went out at the same time. I have checked most of the bulbs, (the ones that are fairly easy to get to) and found them to be OK. Also checked the wires between the front lights and the UEC (fuse box). Baked the UEC at 80c over night to get rid of moisture in case that was the issue, but still the same...
    Is this most likely a fault within the UEC, or could it also be the light switch? (I haven't tried baking the light switch yet) Anyone had a similar problem? Is there a way to test the light switch?
    One other weird thing that I think also happened around the same time is the wipers only running continuously and stopping right where they are when turned off (not parking). Maybe related, maybe not...
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    scan the car, faults like this always leave a DTC
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 310 k !
    My wipers did that - was the motor. No idea on the lights though
    Apr 2022
    romania
    8 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    Bake the light switch? Just unplug it, clean the pins, and replug it, see if it works.
    Full Member sulten's Avatar
    Øvre Årdal, Norway
    13 Post(s)
    Vehicle : Opel Vectra C
    Trim : Cosmo OPC Line
    Interesting collection of errors.
    What do all the errors have in common, UEC? Grounds?...
    Do you have error messages but the lights work or don't work?
    I think you can rule out the switch, the switch does not control the lights directly like in the old days but tells the module to turn on the lights.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    UEC & ABS connector .... including the common ground oints on the engine all should be cleaned DTC erased after that than scanned again to see what comes back... most likely all gone... also check resistance on the fuses... on my car they had to much resistance,which the canbus network picked up on... solution was putting in new fuses. Be smart buy a blister pack of mini/ normal and big fuses of Amazon or eBay as they are a lot heaper that way than buying them from the likes of any of the carpart stores.
  1. Weird Washer/wiper issue
    By Chrish_SRi in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2014, 02:07
  2. Limp mode, MIL light, traction light and weird speedo
    By waxhead38 in forum Engine & Drivetrain
    Last Post: 29th August 2013, 09:21
  3. Weird problem
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2011, 19:12
  4. Weird indicator/light problem
    By mickynoakes in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2010, 23:23
  5. weird possible ABS problem?
    By Xerath in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2010, 15:46
