Results 1 to 5 of 5
Thread: Any other vx use same rear wheel bearing kit?
    Nov 2011
    devon
    Vehicle : vectra 1.9 cdti
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    Default Any other vx use same rear wheel bearing kit?
    Simple enough question, as I have looked around and although I have been told the vectra rear wheel bearing is different, the specs in say a zafira b look the same, so as just curious if anyone has fitted a bearing kit from another vx, as oy thing I can't be sure about is if the mounting studs are a different pattern/width to the zafira, astra etc on a 5 stud.
    Mine are on way out and found some for a zafira b for lot less than a vectra, photos looks very similar, but nobody has them as same pt number?
    Full Member sulten's Avatar
    Oct 2008
    Øvre Årdal, Norway
    13 Post(s)
    Vehicle : Opel Vectra C
    Trim : Cosmo OPC Line
    Engine : Z19DTH
    I think mounting a Zafira or Astra bearing will affect the track width.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Apr 2022
    romania
    8 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    I doubt they will fit, the inner diam is a tad different, you could try but honestly i don't see why would you.
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    the ones that will be the same are the cars that are built on the exact same platform: saab 93 would be your best bet... but if they are cheaper? probably not.
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 151k
    Just catching up, inner diameter is same apparently, which makes sense, but being not that clued up, if track is where the wheel sits off the mount, I did think that, but would have thought the zafira might be same width car?
    Only asking as found a couple of lucas, very local for peanuts but lucas website is useless and not tons of info on it can be found.
  1. Rear wheel bearing gone ??
    By Curry230275 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th July 2015, 11:29
  2. rear wheel bearing
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2011, 19:19
  3. rear wheel bearing??
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 22:14
  4. Rear wheel bearing
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2006, 16:23
