Thanks Thanks:  1
Thread: N/S Front brake issue now, advice please
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Default N/S Front brake issue now, advice please
    Hi hoping someone can give us some advice on the front n/s brake sticking on.Was out driving earlier and when got home could smell a burning smell which i knew was a brake smell.Felt both wheels and the front n/s was hot.Jacked car up and removed road wheel.tried to turn brake disc and it was really stiff to turn.stripped the brakes down ,pads are ok and so is disc
    .piston in caliper pushes back ok with g clamp .Pumped the brake pedal slowly to see if piston moved which it did but noticed brake fluid resevoir went to min (it was ok before hand as it was first thing i checked).so i topped up the resevoir and put evrything back together and pumped the brakes again but the disc was quite stiff again .
    Iknow that the hoses also can cause issues but the piston moved ok.Any ideas ?cannot see any leaks anywhere .Drivers side is ok. p.s slider pins are ok.
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 310 k !
    Possibly 2 issues
    First is a sticking calliper. That'll be one of three things:
    Corrosion in the slider rubber bores on the calliper restricting the rubbers or corrosion on the pins; corrosion under the dust seal at the piston interface; hose breaking down / restricted
    Then there's the fluid loss
    Check the pipe over the top of the rear axle especially
  3. Thanks automan thanked for this post
  4. #3
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Thanks for reply ..got a brake fluid leak at the back it ****ed out .would this cause the front wheel though to get hot and stick.cheers
  5. #4
    Norfolk
    15 Post(s)
    Mileage : 310 k !
    As I said, I think you have 2 snags. Check that sticking calliper for piston and slider corrosion
  6. #5
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    You were right over where the leak is ..took wheel off and can see it dripping on axel .been quoted £120 to do full line ..slider pins are fine i cleaned them again after i checked caliper yesterday but they were ok as i cleaned brakes up a while ago after replacing rear discs and pads .fronts looked ok so just cleaned everything when i did wheel bearings on front a few week ago.Thanks for response.
  1. 302mm Front Brake Upgrade Issue with Carriers
    By Seagulls76 in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2019, 15:18
  2. Brake pad issue
    By valleyboy in forum Suspension, Wheels & Brakes
    Last Post: 17th March 2016, 12:54
  3. Vectra c front brake squeak advice
    By luke300586 in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2014, 19:34
  4. Front brake pad problem, constant rattle until brake pedal is depressed
  5. Brake Issue
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 20:38
