Thanks Thanks:  17
Likes Likes:  76
Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 107
Thread: Hello From Hungary... Soon, Maybe Goodbye to my Vectra.
  1. #91
    Regular Member Kill_Rill's Avatar
    Nov 2023
    Hungary
    Vehicle : 2007 Opel Vectra C 3.0 V6 CDTI
    Trim : Cosmo
    Engine : Z30DT Isuzu DMAX V6
    Mileage : 258600 km
    I swapped back to v-power and the issue is still there. Took it to the mechanics and they read for codes with Tech2 but they said they found no codes. They said it sounds like there is a problem, the bell is clicking. But they also said I should go to specialist.
  2. #92
    Nov 2023
    Hungary
    Trim : Cosmo
    Mileage : 258600 km
    I will add a bottle of STP Diesel Injector Cleaner to the tank and see how it goes. That said, I will stick to premium fuel for the rest of this cars lifetime, it seems as if the car just prefers premium diesel.
  3. #93
    Nov 2023
    Hungary
    Trim : Cosmo
    Mileage : 258600 km
    Another diary update. Here's how I am getting on with the car 1 year after ownership. Check out my video on YouTube: userupdate | 2007 Opel Vectra C 3.0 V6 CDTI Diesel Review in 2024 https://youtu.be/DZghukRdIrE
  4. Likes horaa liked this post
  5. #94
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Default Discover Casual Dating Opportunities in Your City Tonight
    This post requires you to click the Thanks button to read this content. This post requires you to click the Likes button to read this content.
  6. #95
    Nov 2023
    Hungary
    Trim : Cosmo
    Mileage : 258600 km
    P0115-07 & P0115-71 Engine Coolant Temperature Sensor Fault
    Happy New Year Vectra Fans. I need an expert's opinion, pertaining to the Z30DT: Where is the Engine Coolant Temperature Sensor located? What can I find it? Thanks, if you can help. I have a fault code from the ECM, P0115 - Engine Coolant Temperature Circuit High Input; (07) - Present, and I have a code from IPC P0115 - Engine-Coolant Temperature Sensor Circuit Range/Performance; (71) - Present
    Symptoms: Spanner, EML light on, Radiator Fan is blowing at maximum speed, High Idle @1000RPM when no throttle pressure is applied, temp gauge does not rise above 70C, Test menu on BC screen shows coolant temp at 73C even after a 30 minutes' drive - temperature does not change (my opinion would be that the 73C reading is faulty and not accurate.)
    Troubleshooting Performed: Cleared codes, charged battery, swapped batteries - Symptoms still exist after troubleshooting (my guess is the coolant temperature sensor is faulty.)
  7. Likes northpole liked this post
  8. #96
    Apr 2022
    romania
    8 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    Here, download them, sensor and thermostat are doable in the driveway
    https://we.tl/t-O3lZ6AONAa
  9. Thanks Kill_Rill thanked for this post
    Likes Kill_Rill, northpole liked this post
  10. #97
    Nov 2023
    Hungary
    Trim : Cosmo
    Mileage : 258600 km
    Thanks a lot! This is super useful. It's a big help.
  11. Likes northpole liked this post
  12. #98
    Nov 2023
    Hungary
    Trim : Cosmo
    Mileage : 258600 km
    Just to confirm, this is the ECT, right?
  13. Likes northpole liked this post
  14. #99
    Nov 2023
    Hungary
    Trim : Cosmo
    Mileage : 258600 km
    The mechanic said that it was broken. I had it replaced with a Hella aftermarket ECT. Car is running fine again. No EML on the dashboard.
  15. Likes northpole, horaa liked this post
  16. #100
    Nov 2023
    Hungary
    Trim : Cosmo
    Mileage : 258600 km
    Update: it has been more than a month since the last mechanic visit and there has been absolutely zero issues. KNOCK ON WOOD.
  17. Likes horaa liked this post
  1. hy !!! from hungary but VXR :D
    By POWERIVAN in forum Introduce yourself.
    Last Post: 10th November 2017, 16:20
  2. Goodbye vectra...goodbye my friend !
    By n8sby in forum General Chat
    Last Post: 26th January 2013, 15:36
  3. hello from Hungary :D
    By jini in forum Introduce yourself.
    Last Post: 22nd January 2010, 18:44
  4. Hello, from Hungary
    By Arnie in forum Introduce yourself.
    Last Post: 10th June 2009, 20:19
  5. Greetings to all from Hungary!
    By z.Solo in forum Introduce yourself.
    Last Post: 17th September 2007, 13:57
