Likes Likes:  3
Results 1 to 10 of 11
Thread: Vectra 3.2 intermittent misfire.
    Oct 2012
    Chislehurst
    Default Vectra 3.2 intermittent misfire.
    2003 Vectra GSI, 187k miles.# Old, battered, much loved.
    So, I'm engine braking down a hill on the motorway, 5th gear, 1500rpm. Check engine light starts flashing...
    Curious. That's a misfire warning then. Application of right foot to accelerator shows a dead miss on one cylinder. Ten seconds later it clears, and all is well.
    I drive 100 miles a day to and from work. Mostly M25.
    A few days later, half way to work it shudders, and a few seconds later the misfire's back. Doesn't feel like an ignition miss (not sensitive to throttle position). Pulled onto the shoulder, turned it off, turned it on again - all good. Drove to and from work.
    A few days later it returns - over the course of ten seconds I lose pretty much all power, violent shaking. Rolled onto the shoulder. Sat there for a few minutes, looking at my scan tool which was plugged in for the whole drive. Nothing really to see - fuel trims and O2 looked fine until the moment I put the clutch down and pulled in.
    The only fault codes stored are misfire - sometimes it's cyl 3, sometimes 1 or 5, on one occasion 6. Got a P0300 random misfire code as well.
    Gave it a brand new Bosch MAF and fuel filter halfway through this - no change to the fault.
    I'm really stuck. I've got no direction to go in. It had coilpacks and plugs a year / 20k miles ago (genuine Bosch) following a coil failure.
    My bit of the M25 has no hard shoulder for a lot of it, and losing an engine there would lead to a very stressful time.
    I'm nervous about driving it on the motorway.
    The fault never occurs other than on a prolonged motorway drive (50 - 60mph). Won't do it on the back roads - driven gently, or driving it like I stole it.
    Any ideas?
    Doesn't feel like an ignition miss.
    First time it did it, I think was in an RPM range with closed throttle that indicates the injectors weren't being called upon to fire (injector shut-off seems to happen above 1000rpm in 5th with foot off the accelerator when operating normally). I think this points away from it being an injector or fuel pump issue.
    Not the MAF (replaced).
    Is this a failing crank sensor? I can't picture what else would trigger the misfire monitoring whilst coasting downhill.
    When not playing up, I can drive it gently, or try to break the sound barrier and it's fine.
    Any ideas?
    Dec 2019
    Middle
    Trim : SW
    My guess:
    * camshaft sensor / crankshaft sensor
    * ground wire
    Greets Andre
  3. Likes bibu16v liked this post
  4. #3
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    crank or cam-sensor(s)
  5. Likes bibu16v liked this post
  6. #4
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    30 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Oh don’t forget ecu fault !!! and when was cam belt/tensioner last changed. a live data run recorded can show up things that can show what is the problem. o.c/v. is a good software to use on these better than some others.
  7. #5
    Oct 2012
    Chislehurst
    I was wondering about it being a cam / crank sensor.
    The fact that it did it whilst coasting down a hill makes me think it can't be injector or spark related.
    It hasn't thrown any cam / crank correlation codes.
    When it did it the other day, I turned the car off and then immediately re-started it and the fault cleared. I have it in my head that when the crank sensors start to fail, typically you get a no-hot-start as part of the problem - which I don't seem to be experiencing, but I could be wrong about the no hot-start thing being common.
    It got a timing belt kit fitted in the summer (with the correct tools to set the cam timing).
    I'll have a poke around the wiring tomorrow, and see if I can get my hands on a couple of sensors over the weekend.
    I've got some data I recorded with a scan tool. It shows nothing odd on the lambda readings for either bank until I'd actually pulled over after one of the incidents.
    I've been driving to and from work on the back roads all week (two hours each way - it's killing me) and it won't break like that, so I've not got any useful scan tool data.
    I've got a Snap-On Verus - open to suggestions about what PIDs to record / graph on a test drive. I'm struggling - O2 sensors, fuel trims, MAF... can't think of what else might be insightful.
    Does anyone know the symptoms of a failing ECU? There's one for sale on Ebay at the moment, and I think I can probably do the coding / programming if I buy it (but £240 if it's not the fault would hurt a bit).
  8. #6
    Oct 2012
    Chislehurst
    Genuine GM cam and crank sensors on order.
    Is there only one cam sensor? Or is it one per bank? Car's parked out on the road and it's dark outside at the moment.
  9. #7
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    35 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Quote Originally Posted by paulvectra3.2 View Post
    Just one, and it's on the front bank of cylinders, exhaust camshaft, if memory serves.
    Did you resolve your misfire? Sorry if I've missed you posting about it. I haven't been on here for a while.
    Paul
  10. #8
    Oct 2012
    Chislehurst
    Quote Originally Posted by GSiFan View Post
    Paul
    It's funny that you should ask that at this time...
    So, I replaced the crank sensor, and all has been well for a few thousand miles.
    Until yesterday. M25, approaching the Dartford crossing... misfire.
    It cleared after perhaps 10 seconds and hasn't returned. In hindsight, the car had felt a bit lumpy of recent days.
    I needed to drive 50 miles to work today, and don't have any other vehicle. I had a new cam sensor sat on the kitchen table which I bought a few months back, and as it's (a) an easy thing to fit on the side of the road and (b) I had no other ideas, I chucked it on. The car was happy this morning, and - perhaps this is wishful thinking - seems smoother.
    Time will tell.
  11. #9
    35 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Hmmm. Keep an eye on it, I guess. Is the engine management light on? If it is, you can read the fault code, and it might be some help, though not always.
    Paul
  12. #10
    Sep 2015
    Norwich
    30 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    When were the plugs and coils last changed.
  1. Intermittent misfire / judder under acceleration - No fault codes... help!
    By coalfield in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2014, 08:55
  2. Intermittent misfire on one cylinder
    By elfrider in forum Engine & Drivetrain
    Last Post: 24th August 2014, 11:32
  3. Intermittent misfire, codes P0354 and P0304
    By poddy in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd November 2013, 10:02
  4. Vectra 2.2 Direct intermittent misfire?
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 05:59
  5. Intermittent hesitation / misfire / fuel starve
    By rheumatoid in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 10:35
