Thanks Thanks:  3
Likes Likes:  2
Results 1 to 10 of 20
Thread: Vectra 2.8 turbo not starting.
    New Member EliteBadger's Avatar
    Jul 2022
    Far North
    Engine : 2.8 v6 Z28-NET
    Exclamation Vectra 2.8 turbo not starting.
    Hi folks,
    I'd hoped my first post on here would be to ask something less doom laden but hey, it is what it is.
    I have an ex police 2.8 turbo, shes been grand since I got her but not today.
    I fuelled her up to about 2/3rd of a tank, she started and drove away fine, went to see a mate, she stopped and started there fine too. Then went to a shop a couple of miles away, when i came out she would crank and even start and rev up to about 500rpm, then she would stall.
    Never had this kind of issue, she's been fuelled and ran many times. I plan to go back to her this eve and disconnect battery/ discharge her and get any fault codes read. But no warning lights come on dash so I dont know if there will be many codes to read.
    Cheers for any advice and if you need further info just ask.
    Jul 2022
    Far North
    Update, went back to her an hour later and shes still cranking but not starting. Engine management and service lights are on too.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    331 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Look in troubleshooting instead of this none technical issue thread, someone might have had similar in the past.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Jul 2022
    Far North
    Default Vectra 2.8 turbo cranking but not starting.
    Left her for about an hour and when i returned, she would still crank, but nor fire at all and the engine management light is now on.
    Got a mate to read the codes off the ECU and there are no trouble codes, not even showing that the engine managment light is on.
    I am at a loss and really could use any advice on where to start looking.
  5. Thanks NeilGo thanked for this post
  6. #5
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    24 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Get codes first see what’s there. Could be maf or crank/cam sensor.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2022 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
  7. #6
    Sep 2018
    Herts
    16 Post(s)
    Trim : Best
    Engine : 2.0T
    Might be as simple as dirty/blocked fuel filter, might be something as complex as stretched timing chains, which the 2.8 can suffer from. As peeps above have said, extract the fault codes first, then post them on here. If you don't have a code reader, £20 will buy you a decent one on Amazon.
  8. Thanks NeilGo thanked for this post
  9. #7
    Jul 2022
    Far North
    Thanks for the replies guys, I got my mate to read the DTC's and there are none. We cleared them out 2 weeks ago when i got the car to give me a baseline. It's not even showing the MIL is on but my eyes looking at the dash say differently.
  10. #8
    Jul 2022
    Far North
    I may be being a totaly bellend here, but does MIL stay on until engine is running? could swear mine didnt but found a vid where it does. If so, i think i'm going to get a new fuel filter the morn.
  11. #9
    Sep 2015
    Norwich
    24 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Stays on till running, if stored faults passed stays on for 4 secs, if faults present stays on depending on what fault.
    what are you reading faults with as not all codes can be read by the basic crappie readers.
  12. #10
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    79 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    yes at least invest in the cheapest solution opcom so you can readout the car or find someone near you that has either tech2 or opcom to readout the car properly. as a non-start can entail a whole load of things... but mostly either ignition/ fuel/ sensor related if it was the immobilizer the car wouldn't even try to start plus you'd have the key warning light on.
  1. Turbo for my Vectra C 2006 2L Turbo.
    By remco1974 in forum Petrol Engine related
    Last Post: 6th May 2016, 13:08
  2. Vectra VXR turbo swap for Insignia VXR Turbo
    By rajveer.sandhu in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2013, 19:58
  3. Vectra C 2.2 DTi - Not starting !!!
    By tayzaa in forum Engine & Drivetrain
    Last Post: 19th May 2013, 22:46
  4. Starting to like my vectra now !!!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 01:07
