Likes Likes:  9
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Dash light for blown bulb, but no blown bulb
  1. #11
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by horaa View Post
    You will be amazed but if you pull out your rear lights you might see that at least one of them will be blacker than the other, that one will blow up soon for sure. They don't usually blow out in the second you get the light in the dash as they still make a fair good enough contact to still bright.
    I have replaced recently a rear brake light when the check control told me a brake light was out. Guess what? It took me 4 days to swap it and it was still working but it was blacker than the other wich was a sign that the bulb will go out soon. This being said, check all your bulbs, there will be one at fault.
    The other thing to check is bad connection but that takes time while checking a bulb takes like 10 minutes.
    I’d like to see you check the rear lights in the tailgate in 10 mins
    All this talk yet no one know what body it even is as it’s different on the various body types
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  2. #12
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    it doesn't matter... he needs to check the bulbs, connector and the bulb holders .... regardless of body type, that is how you trouble shoot it if you don't have access to tech2 or op-com..so if he decides not to disclose what model he runs that is up to him. #getyournickersoutofthetwist
  3. Likes bibu16v liked this post
  4. #13
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    It does as estate is different set up and some people miss it. Opcom tech2 won’t show you anything more than the light out warning, so if that’s not saying which light it is then your ******ed. Thing is here, we’re covering old ground again and also guessing on what car it actually is when theres all this with pictures and in car diarys
  5. #14
    Apr 2016
    Ipswich
    93 Post(s)
    Year : 2003
    Mileage : 140000
    I got a pre facelift half canbus car and op-com tells me exactly what bulb is out.... so it must be the exact same on the facelift with the full canbus... and even if it doesn't.... the method I described goes for all cars not just the vectra models/signum... regardless of where the bulbs are located... he will still need to check the bulbs, bulbholders and the connectors... or do you want to say that the bulbs in the hatch on the estate or signum estate are not connected to any form of electricity? Now slow your roll and keep your frustrations away from a simple question that has been answered properly... yes not model specific but hey ho he didn't disclose that info not even after you asked for it... so general trouble shooting it is than.
    You make life difficult for no reason... hence my comment on that link of the Mokka forum.
  6. Likes horaa liked this post
  7. #15
    Sep 2018
    Southampton
    Vehicle : Vectra CDTi
    Trim : Exclusiv
    Engine : 1.9
    2007 facelift hatchback 1.9 cdti 120.
  8. #16
    Sep 2018
    Southampton
    Trim : Exclusiv
    Engine : 1.9
    I’ve checked all bulbs and none are blackened. All work as they should (girlfriend in drivers seat) including fog and reverse lights.
  9. #17
    Sep 2018
    Southampton
    Trim : Exclusiv
    Engine : 1.9
    Tomorrow I’m going to replace all 8 bulbs (4 in each cluster). See if that sorts it
  10. #18
    Apr 2016
    Ipswich
    93 Post(s)
    Year : 2003
    Mileage : 140000
    when you do that clean up the bulb holders on both sides... something you should've done when checking the bulbs yesterday, it's not that hard the lot just clips out, and cleanup the pins that the connector clips onto also... that way you eliminate years of dirt/corrosion buildups causing to much resistance (the canbus system picks-up on that)
  11. Likes bibu16v liked this post
  12. #19
    Sep 2018
    Southampton
    Trim : Exclusiv
    Engine : 1.9
    I had a look at where the bulbs sit and there’s minimal corrosion on both bulbs and bulb holders. But yea, will give it a proper clean when the bulbs are all being replaced.
  13. Likes bibu16v liked this post
  14. #20
    Full Member
    May 2008
    UK
    Quote Originally Posted by Khare View Post
    personally i would spray any electrical contacts with contact cleaner/ lubricant while the bulbs are out and plugs disconnected eg RS 917-5914
  1. Blown Rear fog light bulb
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2011, 02:08
  2. bulb warning light on....but no bulbs appear blown
    By rjw in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2010, 01:18
  3. Blown bulb warning light
    By Ant S in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 23:09
  4. Blown bulb indicator on dash.
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 16:20
  5. Blown bulb warning light on dash??
    By Genterz in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2008, 11:10
